gerry
gerry's Achievements
  1. what set do you have to run the servo motor,do i have to get cables made,what the easyer and cheaper,can i run banshee harness w
  2. hey man ,i have rz top end on my 2001 banshee but servo motor is not hook up where and what do i need to run power valves,could u tell me how u did it ,did u use the banshee harness cause that what i have and it runs but powervalves are not hooked up thanks
  3. yes i had to dent left side where the powervalve is for the pipe to be close to the frame
  4. bearing in carrier i had the same thing happen
  5. i thought vforce3s are for drag i read up on here,i have rz top end
  6. whats the best reed valves for the stock reed cages
  7. How to know if there sync the same,how to sync carbs ur self
  8. i have a o1 banshee with rz juggs but powervalve are not hooked up,i have pro circuit pipes front to back with kn filter with 300 main jet.i bought it two yrs ago and end of last summer left cylinder was back firering and head pipe was hot,so i took compression test 60 psi in left ,100 in right,.it still runs but i want to rebuild anyone have suggeastion want i should be looking for when i tear apart engine,teared boot ,crank bearings seals ecy. o yeah and my spark plug was grey like.
  9. soory but dont understand iam from moncton new bruniswick canada one one knowns about banshee with rz swap,i bought it like this.
  10. what size carbs should i be running for rz 350 juggs on my banshee and how do i tell what size is on it is it marked bought banshee with rz juggs on it.
  11. i not sure if bad where can u get new packing does it have to be from pro circuit thanks
  12. i have a question for u guys is it bad to take out packing out of silencers,i have pro circuit on my banshee and i took the packing out for more sound is it going to hurt the engine,thanks
  13. what is his email,does this guy do the swap and knows lots
  14. so where should i look for on ebay for parts i need to make ypvs werk.the bike runs with the jugs on it work good but would work better with powervalve hooked up so i read,does anyone have pics of step of there swap with stock wiring would help me more,but thanks guys for replys cause in moncton new bruniswick no one knows about this swap,the buddy i bought from bought it swap already and he didnt know much.later
