AKheathen
    3
  1. holly fucking red batman! sounds like just what you were looking for. interesting kicker. looks home made
  2. don't you just love that punch
  3. is it just a chrome stockker? pics?
  4. 10.00 + ride for cracked light
  5. uh-oh, you just propigated another run-on oil thread, including every iol known to man. i use xylene in the fuel, and lacquer thinner in the tranny :biggrin:
  6. rewinding the stocker is about the best option out there, unless a fucktarddd does itta. or were you talking about diong it yourself? pickup gap... do a search, or use a buisness card. it's been posted so much, i don't feel lke sayin 18-20 again. damn it1 i said it again
  7. i would check for airleaks on that side, and pop the top and check it out
  8. when you set the pickup, check both nodes on the flywheel. rs is notorious for being out of round/timing on the flywheels, and bad connections in the stator itself. have you checked your reeds? hold your hand over the left carb and kick it over. your hand should get sprayed with fuel, but not pumped off
  9. sealevel?
  10. oh, that setup will never work :biggrin: what you need is a 150mill twin ported super cool boost bottle :thumbsup: just so happens, that i'm in a good mood, and will trade you one strait across, and dispose of that old 4 mill properly for you :tongue:
  11. actually, some parts stores might have them. i buy mine at sno-go shops, though
  12. it's just there to gaurd against chafing. just wrap electrical tape, or heat shrink at any chafing points
  13. and which fmf pipes? filter setup?
  14. fnally got around to reading this novel. what you were experiencing was washout on your plugs. you may want to consider going a little leaner on your oil, too. does it smoke alot? what fuel are you running?
  15. well, actually, that depends on the fuel. if you run local pump 93, then you'll probably end up down 2 sizes. if you run sunco, or other higher octane fuels, than the fuel will be formulated the same no matter where you get it, so then you go up a couple of sizes, actually between 2-3 sizes, like stated
  16. just go match it up. my 86 toyota pickup, and 90 4runner used the same cap
  17. haha, i was wondering when you were gonna chime in :biggrin: i was taling about stock carbs. so, you suck, huh? that's gross :yucky: i just threw that in as an option since i have'nt seen anyone fcuk with ya yet, but, i guess you're admitting it now :yelrotflmao:
  18. ummm.... your title mentions a shifter?
  19. yah, you need both, or it will start spitting oil out of the back one when you wheelie/ hillclimb
  20. most common problems are the choke tube not connected, and bad grounds; pickup gap too. are you getting good blue spark?
  21. x2, you're gonna have to pop the cover and see what's up. how much end play do you have? did you end up with an extra thrust washer after the build?
  22. no shit, the machine shop had a billoin m6x1.0 up here @ work, but .75 is impossible to find, here, and in town.
  23. haha, no problem. did you unplug the wires? the switch will fail eventually, and you'll have to do it anyways. oh, and i'd go up on the jetting, or at least do a plug chop to make sure it's not lean.
