holeshotkid
Everything posted by holeshotkid
  1. That was the sickest move I have ever seen in freestyle.
  2. I'm sure it will be hot but we'll keep the beer on ice and the air conditioner cranked. I have never tried the mexican restaurant and unless the grill breaks, doubt I ever do. Sounds like it's not worth the risk. :biggrin:
  3. LOL. I try to stay off the pavement as much as possible. Our paddles are wearing fast enough. It's been five weeks since we were there and I cant wait to get the family back down there for some fun in the sand.
  4. Heading to the dunes on the 13th. Any of you other hq'ers going to be there?
  5. I run amsoil 0w40. As far a the filter goes, I run the WalMart Supertech 6607. It has the same tool stamp on the filter as a Wix and at just over 2 bucks a piece, you cant go wrong.
  6. Cam sprocket bolts: stock cam 14 lb/ft / Hotcam 9 lb/ft (use blue locktite on the bolts) Cylinder head: 27 lb/ft on the six main bolts / 7.2 lb/ft on the small allen head bolts Rocker cover: 7.2 lb/ft on all the bolts Hope this helps.
  7. Thanks Jared. I was equally impressed with the fast payment. Thanks again
  8. Sound good, we will be in a white 24' v-nose enclosed with a white 01 Z-71. Holler at us if you get the chance.
  9. Man, I wish my wife would let us leave wednesday night. I need to try to find at least two spots together as my sister-inlaw and her husband are pulling down with us. I'm hoping it's going to be not so crowded so we can all camp together as I find it hard to walk around after the sun goes down and I park the quad. Those damn cables have a tendency of tipping me over after dark when I've been hitting the bottle.
  10. Hey Ron, We are planning on being there before noon. The plan is to be in the Cowboy camp or the north camp. You want us to try to save you a spot if possible? What time are you planning on being there? As for Tracy's banshee, don't ask.......
  11. Don't forget Gina's hot pink blaster
  12. The veiw is better from up here.
  13. Just checking to see if any members are going to be at Little Sahara, OK the weekend of June 1st through the 4th. It's time for our first trip of the year. Sand and ice cold beer, I cant wait..
  14. I agree with that, I was just making the point that they are not a direct bolt up cage. With enough work, you can get jut about any cage to fit. On that note, how did they work for you? Any noticable improvement?
  15. No. The bolt pattern is slightly larger on the blaster cage.
  16. Happy Birthday Tracy! The BIG 18
  17. Maybe he is on dial up. Have you ever tried to do a search on dial up? You might get the info your looking for in a day or two...
  18. Happy Birthday! How many does that make now?
  19. Blaster hubs will fit on a warrior/banshee/raptor axle. The bolt pattern for the wheels are different but if you already have the rims and tires for the blaster hubs, your good to go.
  20. Ours are pretty basic. Lose the governor, change the pulleys and bolt the wheels on good. Of course some of us have milled heads, porting, ect.... No suspension, so the ride is a little harsh and the handling is something to be desired. It's cheap fun though but they can get a little twichy at higher speeds.
  21. Racing mowers are a blast. I took 2nd place it the points last year at our local track. They don't handle that great but there is nothing like powersliding a riding mower around a corner. Here is our old web site. Our new web site is under construction http://www.angelfire.com/ks3/rclmra
  22. I also have as set of FMF power core II silencers that will fit stock of fatty series pipes.
  23. Oh really, I have a set a banshee hubs that fit on my son's 400ex. They are a little loose on the splines because (although they are the same splines, the yamaha axle is slightly larger in diameter) but once you crank down on the nut, they tighten up. You also have to cut a spacer on each side that fits over the axle before installing the hubs because the honda hub is slightly wider than the yamaha hub. With that said, the honda hub will not fit on a yamaha axle. The hub will only slide about half way on because the difference in the axle diameter.
  24. I was thinking that same thing. So whatcha coming here for? Is there something going on that no one told me about?
  25. Tony, I sent you another e-mail.
