sleeper06
    20
  1. I have a set of shearer inframes with an air box,i called matt shearer and asked him to make me a set of custom rear bends,there tits and fit great,took some time but its not his ordinary shit I can get picks later if u want
  2. sleeper06
    Dyno
    I live on Long island,cant find a Dyno anywhere,If someone has a clue where one is chime in I will travel
  3. In my drag bike I have ran both,I became a dealer with amsoil and get good prices that way,now I deal with jeff at FAST alot so he orders me supertechniplate,I really like how the motor looks when it comes apart with the techniplate thats what counts to me.I dont know if its becuase I ran it for so long but I have seen many cranks take the fall with amsoil.
  4. Its added protection against welding the clutch rod to the ball
  5. Check the bore sixe with a mic and get back,there probably sleeved cylinders big bore
  6. Time to invest in an alarm and survailance,my house is all tricked out just waiting for someone to try something,i live in a nice area but thieves dont rob bad ones,by the way I FUCKING HATE COPS !!!!!! Also sorry to hear that
  7. I ported my cousins bike,stock carbs ,air box,+4 timing,T-5s,milled head after porting.This thing eats my buddies 700r
  8. Get a few cans of carb cleaner,fill crank with carb cleaner,suck it out with shop vac,then fill again and rotate it,vac it again then oil the shit out of it,sand is nasty though,spin it slow to feel any dirt
  9. If your worried about electronics you can pull the cdi plug,I have welded to many bikes without removing anything with no problem,What kind of welder is he using mig,tig ?
  10. I love compression and race gas,add a lil timing with the gas and your in there.It depends what your used too,I dont think cubs are the handfull everyone makes them out to be either,im used to street bikes.If your not happy he will make it rite.
  11. Please Tate or someone chime in im dying to ride this bitch,I dont want to run them if yet if they can be powdered .or if running them will effect the outcome of powder,thanks for the reply rubberneck
  12. CEL needles start in center ,go from there depending on how bike responds to main jetting
  13. I just recieved my pipes back from shearer for second time,I have not installed them yet because im not happy with the chrome,Im thinking of powder coating over the chrome for a blackchrome affect,do you think it will hold up to the heat well,any opinions would be a great help
  14. Try adjusting your air screws ,go a lil in each direction and test drive it,if not I have used 27.5 pilots with fattys with good results,also have found on a basically stock set-up like yours 240 mains,needles jacked up to the richest position,with air box lid on w/KN filter
  15. Yoy can get a decent carrier for $150 ish
  16. With coil disconnected you should read in the range of 4-7 ohms roughly from plug cap to plug cap,I have 5 diffrent bikes in my garage rite now they read 5.3-5.5 ohms,If you get 5.3 with wires off replace wires and caps with aftermarket,just make sure wires are made for banshee type coil
  17. i have Two testers , one is the rite length, I have tried both and noticed minimal diffrence,0-6 lbs depending on motor,im sure other people will have something to say but,this is what I found
  18. Banshee dan is rite its not a recurculation tank,follow the lines youll see ,I have had five bikes with none the only one that runs it is my drag bike as per track rules,
  19. I dont know anything about an r1 set-up but if you dont loosen the nut it wont adjust,it will just spin,there might be lock-tight on it so try a lil heat
  20. maybe your chasing a diffrent problem,airleak,ignition
  21. Time to repack silencers
  22. I would call him and see if he will do something for you thats some bull shit.I love O.E.M electronics
  23. 100% diffrent,I can post some pics if he needs later,I didnt know the bearing was optional,Jeff got it cut for me,at first I thought they could of done a nicer job with the welds,but all in all its heavily modded in tight places,
  24. I would say its time.
