sleeper06
    20
  1. A guy on this site makes a sick product,I beleive his name on HQ is AZCUSTOMQUADS
  2. Sorry guys I ended up going to englishtown with the bike instead ,of course my boy told me the 11th(you know how that goes)but he meant the 12th,next time ill hit you up
  3. Coil
  4. You need a tig with a rod that will flow easily,I just forget which rod it is
  5. There was so much heat from being lean on the air leak it detonated the fuel,we call it dieseling
  6. That looks damn close tho,is therte a prob with the way shes running
  7. You def need to ship that shit to someone for a clearance check,collapsed skirts from deto
  8. Did you pressure test the motor after the cycles to rule out more air leaks,6lbs for 6min,its a must along with a compression test,squish test
  9. Its really hard to say with just a mic,your micing the skirt not the top rite,if you take a ring off the piston whats the ring gap?Do you have a bore guage?With a bore guage you can check if the cylinders bore is true the whole way down.I had some noise in a motor and it turned out to be an untrue bore.The other thing is,if your detonating you could have collapsed the skirt of the piston,causing some noise
  10. Im running the same motor as you with 20cc domes and I kick 175 both sides,you bought that piece from kubitza rite,did you buy the 19s from jeff also.What size base gasket are you running,those domes didnt come with the motor because he ran alky,just wondering,with 20s I run straight c-12,c-16 VP fuels
  11. i have a futaba digital remte controll and two recievers for gas/electric cars,controller capable of ten cars never have your signal robbed again,Range is rediculous,throttle responce better than stock,has anti-lock braking feature where it pulses the servo for better stopping.It was only used for 1 week then never used,its the new model Will take $200 or trades hit me up if you want it im bringing it to the hobby store monday
  12. You have to unplug the TORS box next to the coil upfront,you will need new throttle cable,trim unused wires if you want
  13. I have a strap wrench that works,or I used to stuff a rag between the basket and inner hub and stratigically place a screwdriver
  14. Sounds close,I ran 340 with one dune port,380 with another,everybody ports diffrent,call A+S to make sure
  15. If any body is interested in riding the streets,through the five boroughs,we meet at a disclosed location with a lot of street bikes,im riding a banshee so are others if you wanna go pm me for info July 11,the event is being filmed for my boys street bike video
  16. Compression is way low
  17. I looked at them wrong the first time,sure got your moneys worth out of it
  18. Whats the lowest you can go on the crank
  19. Im gonna say your float bowls hung open when you crashed or something like that flooding the motor causing it not to run,start
  20. replace the seals,cheap insurance,your right the lock-up on my buddies R1 is a little diffrent,but the one you have works good,I run all stock springs so it reacts like a two step,did you do your tranny?
  21. I run all six stock springs,3heavy-3light weights on the lockout and im pretty happy with its ability to be slipped out the gate on asphault,it also locks when needed
  22. i just met up with this site member today. He gave me what i asked for and more,He has a ton of parts I recommend using him in the future if you need used stuff,he has everything,Again thanks for the stuff today
  23. That guy has to be joking me thinking someone will actually buy that
