fastrthnu
Everything posted by fastrthnu
  1. Most of the bolt applications are in millimeters. You can determine your bolt pattern by measuring from the center of one wheel stud to the center of the opposing wheel stud across the hub. Next, determine your correct bolt pattern. Convert your measurement from inches to millimeters by multiplying by 25.4. It's that simple. Example: Wheel stud measurement: 4-5/16" = (4.313") Formula: 4.313 x 25.4 = 109.6 mm ==> 110mm bolt pattern ARCTIC CAT OEM TIRE SIZE OEM WHEEL SIZE 250 2WD/4WD, 99-03 (F) 23x8x12 12x7, 4/115 250 2WD, 99 ® 25x10x12 12x7, 4/115 250 2WD, 00 ® 24x9x12 12x7, 4/115 250 2WD/4WD, 01 ® 23x10x12 12x7, 4/115 250 2WD/4WD, 02-03 ® 24x9x12 12x7, 4/115 300 2WD, 98-03 (F) 23x8x12 12x7, 4/115 300 4WD, 98-00 (F) 24x9x12 12x7, 4/115 300 4WD, 01 (F) 23x8x12 12x7, 4/115 300 2WD/4WD, 98-00 ® 25x10x12 12x7, 4/115 300 2WD/4WD, 01 ® 23x10x12 12x7, 4/115 300 4WD, 02-03 (F) 24x9x12 12x7, 4/115 300 2WD/4WD, 02-03 ® 25x10x12 12x7, 4/115 375 2WD/4WD, 02-03 (F) 25x8x12 12x7, 4/115 375 2WD/4WD, 02-03 ® 25x10x12 12x7, 4/115 400 2WD/4WD, 98-03 (F) 25x8x12 12x7, 4/115 400 2WD/4WD, 98-03 ® 25x10x12 12x7, 4/115 400i 2WD/4WD, 02-04 (F) 25x8x12 12x7, 4/115 400i 2WD/4WD, 02-04 ® 25x11x12 12x7, 4/115 454 2WD/4WD, 96-98 (F) 25x8x12 12x7, 4/115 454 2WD/4WD, 96-98 ® 25x10x12 12x7, 4/115 500 4WD, 98-99 (F) 26x10.5x12 12x7, 4/115 500 4WD, 98-99 ® 26x10.5x12 12x7, 4/115 500 4WD, 00-03 (F) 25x8x12 12x7, 4/115 500 4WD, 00-03 ® 25x10x12 12x7, 4/115 500i 4WDi, 02-04 (F) 25x8x12 12x7, 4/115 500i 4WDi, 02-04 ® 25x11x12 12x7, 4/115 600i 4WDi, 2004 (F) 26x8x12 12x7, 4/115 600i 4WDi, 2004 ® 26x11x12 12x7, 4/115 BOMBARDIER OEM TIRE SIZE OEM WHEEL SIZE Outlander 330-400 2WD/4WD, 03-04 (F) 25x8x12 12x7, 4/137 Outlander 330-400 2WD/4WD, 03-04 ® 25x10x12 12x7, 4/137 Traxter 500 4WD, 99-04 (F) 25x8x12 12x7, 4/110 Traxter 500 4WD, 99-04 ® 25x10x12 12x7, 4/110 Quest 500-650, 00-04 (F) 25x8x12 12x7, 4/110 Quest 500-650, 00-04 ® 25x10x12 12x7, 4/110 DS 650, 00-04 (F) 21x7x10 10x5, 4/143 DS 650, 00-04 ® 20x11x9 9x9, 4/143 HONDA OEM TIRE SIZE OEM WHEEL SIZE TRX 70, 86-87 (F) 16x8x7 7x6, 4/110 TRX 70, 86-87 ® 16x8x7 7x6, 3/100 TRX 90, 93-03 (F) 20x7x8 8x5.5, 4/85 TRX 90, 93-03 ® 19x8x8 8x6.5, 4/85 ATC 90/110, Thru 81 ® 22x11x8 8x8, 3/100 ATC 110/125/125M, 82-87 ® 22x11x8 8x8, 4/130 TRX 125, 87-88 (F) 20x7x8 8x6, 4/85 TRX 125, 85-88 ® 22x10x8 8x8, 4/130 ATC 185S, Thru 81 ® 22x11x8 8x8, 3/100 ATC 185S, 82-84 ® 22x11x8 8x8, 4/130 ATC 185/200/Big Red, 80-84 ® 25x12x9 9x9, 4/150 ATC 200S, 84/85 ® 22x11x8 8x8, 4/130 ATC 200M, Thru 85 ® 25x12x9 9x9, 4/150 ATC 200X, 83-85 ® 22x11x8 8x8, 4/110 ATC 200X, 86-87 ® 22x10x9 9x9, 4/110 TRX 200, 90-93, 96-97 (F) 21x7x10 10x5, 4/110 TRX 200, 90-93, 96-97 ® 22x10x8 8x8, 4/110 TRX 200, 84 ® 25x12x9 9x9, 4/150 TRX 200SX, 86-88 ® 22x11x8 8x8, 4/110 ATC 250 Big Red, 85 ® 25x12x9 9x9, 4/110 TRX 250 Big Red, 86-87 (F) 21x7x10 10x5, 4/110 TRX 250 Big Red, 85-87 ® 25x12x9 9x9, 4/110 ATC 250SX, 85-87 ® 22x11x8 8x9, 4/110 ATC 250R, 81 ® 22x11x8 8x8, 3/100 ATC 250R, 82 ® 22x11x8 8x8, 4/130 ATC 250R, 83-84 ® 22x11x8 8x8, 4/110 ATC 250R, 85-86 ® 20x10x9 9x9, 4/110 TRX 250R, 86-89 (F) 22x7x10 10x5, 4/144 TRX 250R, 86-89 ® 20x10x9 9x9, 4/110 TRX 250X, 86-87 (F) 22x7x10 10x5, 4/110 TRX 250X, 88, 90-92 (F) 22x7x10 10x5, 4/144 TRX 250X, 86-92 ® 20x10x9 9x9, 4/110 TRX 250 RECON, 97-04 (F) 22x7x11 11x7, 4/110 TRX 250 RECON, 97-04 ® 22x10x9 9x9, 4/110 TRX 250EX, 00-04 (F) 22x7x11 10x5, 4/144 TRX 250EX, 00-04 ® 22x10x9 9x9, 4/110 TRX 300EX, 93-04 (F) 22x7x10 10x5, 4/144 TRX 300EX, 93-04 ® 20x10x9 9x9, 4/110 ATC 350X, 85-86 ® 22x11x9 9x9, 4/110 TRX 300 2WD, 88-92 (F) 23x8x11 11x7, 4/110 TRX 300 2WD, 93-00 (F) 23x8x11 11x7, 4/110 TRX 300 2WD, 88-00 ® 25x12x9 9x9, 4/110 TRX 300 4WD, 88-00 (F) 23x8x11 11x7, 4/110 TRX 300 4WD, 88-00 ® 24x9x11 11x7, 4/110 TRX 350 4WD, 86-92 (F) 24x9x11 11x7, 4/110 TRX 350 4WD, 86-92 ® 24x9x11 11x7, 4/110 TRX 350 Rancher S-ES 2WD 00-04 (F) 24x8x12 12x7, 4/110 TRX 350 Rancher S-ES 2WD 00-04 ® 25x11x10 10x8, 4/110 TRX 350 Rancher S-ES 4WD 00-04 (F) 24x8x12 12x7, 4/110 TRX 350 Rancher S-ES 4WD 00-04 ® 24x9x11 11x7, 4/110 TRX 400 Rancher AT 4WD, 04 (F) 24x8x12 12x7, 4/110 TRX 400 Rancher AT 4WD, 04 ® 24x10x11 11x7, 4/110 TRX 400EX, 99-04 (F) 22x7x10 10x5, 4/144 TRX 400EX, 99-04 ® 20x10x9 9x9, 4/110 TRX 400 Foreman 4WD, 96-04 (F) 24x8x11 11x7, 4/110 TRX 400 Foreman 4WD, 96-04 ® 24x10x11 11x7, 4/110 TRX 450 Foreman S-ES 4WD, 98-04 (F) 25x8x12 12x7, 4/110 TRX 450 Foreman S-ES 4WD, 98-04 ® 25x10x12 12x7, 4/110 TRX 500 Rubicon 4WD, 01-04 (F) 25x8x12 12x7, 4/110 TRX 500 Rubicon 4WD, 01-04 ® 25x10x12 12x7, 4/110 ODYSSEY, 77-81 (F) 20x7x8 8x5, 3/100 ODYSSEY, 77-81 ® 22x11x8 8x8, 3/100 ODYSSEY, 82-84 ® 22x11x8 8x8, 4/130 ODYSSEY, 85-86 (F) 21x7x10 10x5, 4/110 ODYSSEY, 85-86 ® 24x11x10 10x8, 4/130 PILOT, 89-90 (F) 21x7x10 10x5, 4/110 PILOT, 89-90 ® 24x11x10 10x8, 4/130 KAWASAKI OEM TIRE SIZE OEM WHEEL SIZE KLT 110/160/185/200, All ® 21x9x8 8x8, 4/4 KLF 185 Bayou, 85-87 ® 22x11x8 8x8, 4/110 KLF 220 Bayou, 88-02 (F) 22x8x9 9x6, N/A KLF 220 Bayou, 88-02 ® 22x10x10 10x8, 4/137 KLT 250, 82-85 ® 25x12x9 9x9, 4/4 KXT 250 Tecate, 84 ® 22x11x10 10x8, 4/4 KXT 250 Tecate, 85-87 ® 22x11x10 10x8, 4/156 KXT 250 Tecate-4, 87-88 (F) 21x7x10 10x5, 4/156 KXT 250 Tecate-4, 87-88 ® 22x11x10 10x8, 4/156 KSF 250 Mojave, 87-03 (F) 21x7x10 10x5, 4/156 KSF 250 Mojave, 87-03 ® 22x11x10 10x8, 4/156 KLF 300 Bayou 2WD, 85-03 (F) 22x9x10 10x6, 4/137 KLF 300 Bayou 2WD, 85-03 ® 24x11x10 10x8, 4/137 KLF 300B Lakota, 95-00 (F) 22x8x10 10x5, 4/156 KLF 300B Lakota, 95-00 ® 22x11x10 10x8, 4/156 KLF 300 Bayou 4WD, 89-03 (F) 24x8x11 11x6, 4/137 KLF 300 Bayou 4WD, 89-03 ® 24x10x11 11x7, 4/137 Prairie 300 2WD/4WD, 99-03 (F) 25x8x12 12x7, 4/137 Prairie 300 2WD, 99-03 ® 25x11x10 10x8, 4/137 Prairie 300 4WD, 99-03 ® 25x11x10 10x8, 4/137 Prairie 360 2WD, 03 (F) 25x8x12 12x7, 4/137 Prairie 360 2WD, 03 ® 25x10x12 12x7, 4/137 Prairie 360 4WD, 03 (F) 25x8x12 12x7, 4/137 Prairie 360 4WD, 03 ® 25x10x12 12x7, 4/137 KLF 400 Bayou 4WD, 93-03 (F) 24x8x11 11x6, 4/137 KLF 400 Bayou 4WD, 93-03 ® 24x10x11 11x7, 4/137 Prairie 400 2WD/4WD, 97-03 (F) 25x8x12 12x7, 4/137 Prairie 400 2WD/4WD, 97-03 ® 25x12x10 10x8, 4/137 KFX 400 2WD, 03 (F) 22x7x10 10x5, 4/144 KFX 400 2WD, 03 ® 20x10x9 9x9, 4/110 Prairie 650 4WD, 02-03 (F) 25x8x12 12x7, 4/137 Prairie 650 4WD, 02-03 ® 25x10x12 12x7, 4/137 Prairie 700 4WD, 04 (F) 25x8x12 12x7, 4/137 Prairie 700 4WD, 04 ® 25x10x12 12x7, 4/137 KFX 700 2WD, 03-04 (F) 22x7x10 10x5, 4/144 KFX 700 2WD, 03-04 ® 22x11x10 10x8, 4/137 Mule 500 (F) 22x9x10 10x7, 4/137 Mule 500 ® 22x11x10 10x8, 4/137 Mule 1000/2000/2510 (F&R) 22x11x10 10x8, 4/137 Mule 3000 (F&R) 23x11x10 10x8, 4/137 SUZUKI OEM TIRE SIZE OEM WHEEL SIZE LT 50, 86-87 (F&R) 145/70-60 6x6, 3/90 LT 80 Quadsport, 87-03 (F) 19x7x8 8x6, 3/120 LT 80 Quadsport, 87-03 ® 19x7x8 8x6, 3/120 LT/ALT 125, 83 ® 22x11x8 8x8, 3/100 LT/ALT 125F, 84-87 ® 22x11x8 8x8, 4/130 LT 160 Quadrunner, 89-02 (F) 20x7x8 8x6, 4/112 LT 160 Quadrunner, 89-02 ® 22x10x8 8x8, 4/112 LT 185 Quadrunner, 83 ® 22x11x8 8x8, 4/130 LT/ALT 185, 84-87 ® 22x11x8 8x8, 4/130 LT 230 GEG Quadrunner, 85-86 ® 22x11x8 8x8, 4/130 LT 230 GEF Quadrunner, 85-87 ® 22x11x9 9x9, 4/130 LT 230 EH/EJ/EK Quadrunner, 87 ® 22x11x9 9x9, 4/130 LT 230 EH/EJ/EK, 87-89, 91-93 (F) 21x7x10 10x5, 4/166 LT 230 EH/EJ/EK, 88-89, 91-93 ® 22x11x9 9x9, 5/130 LT 230 QuadSport, 85-88 (F) 21x7x10 10x5, 4/166 LT 230 QuadSport, 85-88 ® 22x11x9 9x9, 4/130 LT 250 QuadSport, 89-90 (F) 21x7x10 10x5, 4/166 LT 250 QuadSport, 89-90 ® 22x11x9 9x9, 4/130 LT 250F Quadrunner, 89-02 (F) 22x8x10 10x5, 4/140 LT 250F Quadrunner, 89-02 ® 24x11x10 10x8, 4/140 LT 250E/F/G Quadrunner, 84-86 ® 22x11x9 9x9, 4/130 LT 300 E Quadrunner, 87-90 (F) 21x8x9 9x6, 4/130 LT 300 EH Quadrunner, 87-88 ® 25x12x9 9x9, 4/130 LT 300 EJ Quadrunner, 89-90 ® 25x12x9 9x9, 5/130 LT 250R QuadRacer, 85-92 (F) 21x7x10 10x5, 4/166 LT 250R QuadRacer, 85-86 ® 22x11x10 10x8, 4/130 LT 250R QuadRacer, 87-92 ® 22x10x10 10x8, 5/130 LT 250 4WD, 88-02(F) 22x8x10 10x5, 4/140 LT 250 4WD, 88-02 ® 24x11x10 10x8, 4/140 Z250 2WD, 02-03 (F) 22x7x10 10x5, 4/144 Z250 2WD, 02-03 ® 20x10x9 9x9, 4/110 OZARK 250 2WD, 02-03 (F) 22x7x11 11x7, 4/110 OZARK 250 2WD, 02-03 ® 20x10x9 9x9, 4/110 LT 300 4WD XM King Quad, 91-03 (F) 24x8x11 11x6, 4/140 LT 300 4WD XM King Quad, 91-03 ® 25x10x12 12x7, 5/160 Eiger 400 2WD, 02-03 (F) 25x8x12 12x7, 4/110 Eiger 400 2WD, 02-03 ® 25x12x12 12x7, 4/110 Eiger 400 Auto 2WD, 02-03 (F) 25x8x12 12x7, 4/110 Eiger 400 Auto 2WD, 02-03 ® 25x12x12 12x7, 4/110 Eiger 400 4WD, 02-03 (F) 25x8x12 12x7, 4/110 Eiger 400 4WD, 02-03 ® 25x12x12 12x7, 4/110 Eiger 400 Auto 4WD, 02-03 (F) 25x8x12 12x7, 4/110 Eiger 400 Auto 4WD, 02-03 ® 25x12x12 12x7, 4/110 LT 500R QuadRacer, 87-90 (F) 21x7x10 10x5, 4/166 LT 500R QuadRacer, 87-90 ® 22x11x10 10x8, 5/130 LT-F/LT-A 500 Quadrunner, 98-02 (F) 25x8x12 12x7, 4/90 LT-F/LT-A 500 Quadrunner, 98-02 ® 25x10x12 12x8, 4/90 LT-Z400 Quadsport, 02-03 (F) 21x7x10 10x5, 4/144 LT-Z400 Quadsport 02-03 ® 20x11x10 9x9, 4/110 Vinson 500 4x4 02-03 (F) 25x8x12 12x7, 4/110 Vinson 500 4x4 02-03 ® 25x10x12 12x7, 4/110 POLARIS OEM TIRE SIZE OEM WHEEL SIZE Trail Boss/Cyclone/Trail Blazer, 86-02 (F) 23x7x10 10x5, 4/156 Trail Boss/Cyclone/Trail Blazer, 86-02 ® 22x11x10 10x8, 4/4 Trail Boss 4x4 250/300, 87-95 (F) 23x7x10 10x5, 4/156 Trail Boss 4x4 250/300, 87-95 ® 22x11x10 10x8, 4/4 Xplorer 300/Trail Boss 2x4 350L/400L, 90-99 (F) 23x7x10 10x5, 4/156 Xplorer 300/Trail Boss 2x4 350L/400L, 90-99 ® 24x11x10 10x8, 4/4 Magnum 325 2x4/4x4, 00-02 (F) 24x8x12 12x7, 4/156 Magnum 325 2x4/4x4, 00-01 ® 24x11x10 10x8, 4/4 Magnum 325 2x4/4x4, 2002 ® 24x11x10 10x8, 4/156 Xpedition 325 4x4, 00-02 (F) 24x8x12 12x7, 4/156 Xpedition 325 4x4, 00-02 ® 24x11x10 10x8, 4/4 Sportsman 335 4x4, 99-01 (F) 23x7x10 10x5, 4/156 Sportsman 335 4x4, 99-01 ® 24x11x10 10x8, 4/156 Trail Boss 4x4 350L/400L, 90-94 (F) 25x8x12 12x7, 4/156 Trail Boss 4x4 350L/400L, 90-94 ® 25x12x10 10x8, 4/4 Sportsman 400/Magnum 4x4 425L,95-98 (F) 25x8x12 12x7, 4/156 Sportsman 400/Magnum 4x4 425L,95-98 ® 25x11x10 10x8, 4/4 Sportsman 400 4x4 425L,01-02 (F) 25x8x12 12x7, 4/156 Sportsman 400 4x4 425L,01-02 ® 25x11x10 10x8, 4/156 Magnum 2x4/Xpress 300/400L, 96-99 (F) 23x7x10 10x5, 4/156 Magnum 2x4/Xpress 300/400L, 96-99 ® 24x11x10 10x8, 4/4 Xplorer 4x4 400L, 95-01 (F) 25x8x12 12x7, 4/156 Xplorer 4x4 400L, 95-01 ® 25x12x10 10x8, 4/4 Scrambler 2x4/4x4 400L, 95-01 (F) 23x7x10 10x5, 4/156 Scrambler 2x4/4x4 400L, 95-01 ® 22x11x10 10x8, 4/4 Sport 400L 2x4, 94-99 (F) 23x7x10 10x5, 4/156 Sport 400L 2x4, 94-99 ® 22x11x10 10x8, 4/4 Xpedition 425 4x4, 99-01 (F) 25x8x12 12x7, 4/156 Xpedition 425 4x4, 99-01 ® 25x11x10 10x8, 4/4 Xplorer/Sportsman 500 4x4, 96-01 (F) 25x8x12 12x7, 4/156 Xplorer/Sportsman 500 4x4, 96-01 ® 25x11x10 10x8, 4/156 Magnum 500 4x4, 99-03 (F) 25x8x12 12x7, 4/156 Magnum 500 4x4, 99-03 ® 25x11x10 10x8, 4/4 Scrambler 500 2x4/4x4, 97-03 (F) 23x7x10 10x5, 4/156 Scrambler 500 2x4/4x4, 97-03 ® 22x11x10 10x8, 4/4 Predator 500 2x4, 03-04 (F) 21x7x10 10x8, 4/156 Predator 500 2x4, 03 ® 20x11x10 10x8, 4/156 Predator 500 2x4, 04 ® 20x11x10 10x8, 4/110 Sportsman 600 4x4, 03 (F) 25x8x12 12x7, 4/156 Sportsman 600 4x4, 03 ® 25x11x12 12x7, 4/156 Sportsman 700 4x4, 02-03 (F) 25x8x12 12x7, 4/156 Sportsman 700 4x4, 02-03 ® 25x10x12 12x7, 4/156 Diesel 4x4, 99-01 (F) 25x8x12 12x7, 4/156 Diesel 4x4, 99-01 ® 25x11x10 10x8, 4/156 Big Boss 4x6, 89-94 (F) 22x8x10 10x5, 4/156 Big Boss 4x6, 89-94 ® 22x11x10 10x8, 4/4 Magnum/Big Boss 6x6, 93-01 (F) 25x8x12 12x7, 4/156 Magnum/Big Boss 6x6, 93-01 ® 25x12x10 10x8, 4/4 Ranger, 98-01 (F) 25x10x12 12x7, 4/156 Ranger, 98-01 ® 25x11x10 10x8, 4/156 YAMAHA OEM TIRE SIZE OEM WHEEL SIZE YF 60 Zinger, All years (F&R) 15x7x6 6x6, 3/70 YFM 80E Badger, 93-04 (F) 18x7x7 7x6, N/A YFM 80E Badger, 93-04 ® 20x9x8 8x8, N/A YFM 80 Moto-4, 87-92 ® 19x8x7 7x6, 3/70 YFM 100T Moto-4, 87-90 ® 20x9x8 8x8, 4/100 YFA 125 Breeze, 89-02 (F) 20x7x8 8x7, 4/85 LB YFA 125 Breeze, 89-02 ® 22x10x8 8x8, 4/85 YT 125/175 Tri-Moto, 81-85 ® 22x11x8 8x8, 3/100 YTM 200 E/L/R Tri-Moto, 83/86 ® 25x12x9 9x10, 4/125 YTM 200 DX, 88-90 (F) 22x8x10 10x5, 4/156 YTM 200 DX, 88-90 ® 22x11x8 8x8, 4/100 YSF 200 U Blaster, 88-04 (F) 21x7x10 10x5, 4/156 YSF 200 U Blaster, 88-04 ® 21x10x8 8x8, 4/100 YTM 225 DX/DR Tri-Moto ® 22x11x8 8x8, 3/100 YFM 225 Moto-4, 85-87 (F) 22x8x10 10x5, 4/156 YFM 225 Moto-4, 85-87 ® 25x12x9 9x9, 4/125 YFM 250 Moto-4, 89 (F) 22x8x10 10x6, 4/110 YFM 250 Moto-4, 89 ® 25x12x9 9x9, 4/110 YFB 250 Timberwolf 2x4, 92-94 (F) 22x7x10 10x5, 4/156 YFB 250 Timberwolf 2x4, 95-98 (F) 22x7x10 10x5, 4/110 YFB 250 Timberwolf 2x4, 92-98 ® 22x11x10 10x8, 4/110 Bear Tracker 250, 99-02 (F) 22x7x10 10x5, 4/110 Bear Tracker 250, 99-02 ® 22x10x10 10x8, 4/110 YFB 250 Timberwolf 4x4, 95-04 (F) 23x8x10 10x5, 4/110 YFB 250 Timberwolf 4x4, 95-04 ® 23x10x10 10x8, 4/110 YTZ 250 Tri-Z, 85 ® 22x11x8 8x8, 4/100 YTZ 250 Tri-Z, 86 ® 22x11x9 9x8, 4/100 YFM 350 XT Warrior, 87-04 (F) 22x7x10 10x5, 4/156 YFM 350 XT Warrior, 87-04 ® 22x10x9 9x9, 4/115 YFM 350 Wolverine, 95-04 (F) 23x8x12 12x7, 4/110 YFM 350 Wolverine, 95-04 ® 23x10x12 12x7, 4/110 YFZ 350 T Banshee, 87-04 (F) 21x7x10 10x5, 4/156 YFZ 350 T Banshee, 87-88, 91-04 ® 22x10x9 9x9, 4/115 YFZ 350 T Banshee, 89-90 ® 22x11x10 10x8, 4/156 YFM 350 ER Moto-4, 87-88 (F) 22x8x10 10x5, 4/156 YFM 350 ER Moto-4, 89-95 (F) 22x8x10 10x5, 4/110 YFM 350 ER Moto-4, 87-92 ® 25x12x9 9x9, 4/125 YFM 350 ER Moto-4, 93-95 ® 25x12x9 9x9, 4/110 YFM 350 Big Bear 2WD, 96-04 (F) 25x8x12 12x7, 4/110 YFM 350 Big Bear 2WD, 96-99 ® 25x12x9 9x9, 4/110 YFM 350 Big Bear 2WD, 00-04 ® 23x10x10 10x8, 4/110 YFM 350/400 Big Bear 4WD, 87-03 (F) 25x8x12 12x7, 4/110 YFM 350/400 Big Bear 4WD, 87-03 ® 25x10x12 12x7, 4/110 YFM 400 Kodiak 4WD, 93-04 (F) 25x8x12 12x7, 4/110 YFM 400 Kodiak 4WD, 93-04 ® 25x10x12 12x7, 4/110 YFM 400 Kodiak 2WD, 93-04 (F) 25x8x12 12x7, 4/110 YFM 400 Kodiak 2WD, 93-04 ® 25x10x12 12x7, 4/110 YFZ 450 2WD, 04 (F) 21x7x10 10x5, 4/156 YFZ 450 2WD, 04 ® 20x10x9 9x9, 4/115 YFM 600 Grizzly, 98 (F) 25x8x12 12x7, 4/110 YFM 600 Grizzly, 98 ® 25x10x10 10x8, 4/110 YFM 600 Grizzly, 99-01 (F) 25x8x12 12x7, 4/110 YFM 600 Grizzly, 99-00 ® 25x10x12 12x7, 4/110 YFM 600 Grizzly, 01 ® 25x10x10 10x8,4/110 YFM 660R Raptor, 01-04 (F) 21x7x10 10x5, 4/156 YFM 660R Raptor, 01-04 ® 20x10x9 9x9, 4/115 YFM 660 Grizzly, 02-04 (F) 25x8x12 12x7, 4/110 YFM 660 Grizzly, 02-04 ® 25x10x12 12x7, 4/110 YFM 660 Rhino, 04 (F) 25x8x12 12x7, 4/110 YFM 660 Rhino, 04 ® 25x10x12 12x7, 4/110
  2. F vitos!!! Get a noss!! :thumbsup:
  3. Im thinking about getting some next dry season here. They look pretty gnarly.
  4. no yea that purple power and whatever degreaser shit they sell sucks!!! carb cleaner makes a good insect killer too.
  5. stock cdi is fine. on another note, how are those gear paddles working for you on the rear you have there?
  6. carb cleaner without the lube works great. Just keep it away from seals, wire, and hoses n crap because over time they will dry and crack.
  7. ace hardware, ebay, most good hardware stores should have something.
  8. Im asking around for ya.
  9. If mine is too rich they will burn just as hot as if its to lean. I mean really hot really fast. As long as your head pipe right where it connects to the exaust port isnt bluing, it shouldnt be to off. If its starts to get hot to the point it blues, somethings makin it to hot. Keeping the motor at a constant high rev and not moving fast will do it to. Like 50 donuts in a row.
  10. pm sent
  11. Im going out over here next weekend all weekend again. Its going to fill up with water out here soon. Ill be making my way up north alot once that happens. It perfect right now though.
  12. see if its wet at this property. Im sure if it is, most everyone would prob rather hit the dryer land up higher.
  13. depends on where you are in elevation. Its worth the price to get it. I got mine primarily for cooling, but good looks and performance dont hurt my feeling either. 21 is the safest (general) size with a decent ring seal on premium. Contact a manufacture of the brand you want and ask them.
  14. for half the money I got boyeseen carbon pros and tdr that work just the same. hook up with Tony in Pompano.... www.bansheesuperstore.com
  15. fastrthnu
    Timing Plate!
    Need an adjustable timing plate by next weekend. Mine got ruined. I HATE RICKY STATOR!!!!! PM & Let me know what you have n how much. Dont try and sell me a pro design for some rediculous money either please. Thanx!!
  16. sounds good to me August 3-5.
  17. I dont really care where or when. Any weekend after this one, Im down for. The sooner the better.
  18. how about the thread size?
  19. Anyone know what size the flywheel nut is?
  20. It looks to me that croom hasnt been maintained and is $50 per atv. Looks to me like Big Scrub might be nice, It says its wooped but has as many flat spots for speed unlike croom which is all woop. Its only $6 dollars to say there. Dont know about gas & stores though. The upshot with croom are these things. Im going to try and get my 300ex on the roll to for a backup. Im sure alot of us are going to want to race too :cool: if I remember to leave my gas on hahaha
  21. Im ready anytime after this weekend. I was thinking about riding my backyard one more time the 20-22nd here in Bonita then Ocala or Brookseville 27-29th. I dont know the area well, so someone needs to organize a meeting place. Money no matter and primitive doesnt matter to me. If another weekend is better for the majority, Ill most certaintly change my trip for it. Sooner the better!
  22. ........ Making new thread for this trip :thumbsup:
  23. search "plug chop(s)"
  24. The first style ITP blackwater, Titan realtor, holeshot gncc.
  25. Yeah, ok, so anyways WHEN AND WHERE!!!!!!!!!!
