BaNsHeeJuNkEy
Everything posted by BaNsHeeJuNkEy
  1. what is your pilot now. the smaller the number less fuel the bigger the number the more fuel. so if yous is a 30 now and u put the 27.5 it would lean it out. and don't use half sizes from what i was told only hole sizes. like 20,22,25,28,30. hope this helps you.
  2. that thing is sick i want to build one.
  3. here is a pic of mine on my shee bigger then the normal pwr one.
  4. i have a oversize pwr on mine and my bike will be in the woods in 95 degree weather sitting there and will not over heat. i put engine ice in it and i noticed between the two my motor took longer to get hot and stood a lot cooler i can put my hand on my radiator and cylinder on my shee and it is not hot in the winter and the same on my kx as long as the outside temp is below 40. i love both and will stand by them. good stuff.
  5. i just have uni foams right on the carbs. i am going to put in a 155 main when it comes in from fast should be here wensday or so. and as far as the slides i did the same thing both my adjusters are all the way down and i adjusted the cable at the throtle and they both seem to hit closed at the same time only hear one bank no echo. and they both start to open the same time. got that pertty fast. pilot i know has to go down doesn't rev high almost wants to stall and the plugs are still wet when i pull them out. and the middle ya it stumbles and everything elsa. i got 150-155 coming when i put that in i will post again with news and see what you say.
  6. BaNsHeeJuNkEy
    Loud
    LOL that was funny. talk about getting taken advantage of. but more props for the neighbor for doing it,
  7. that is a good one. but think i have heard it before,
  8. shit i thought he was getting it from everyone,
  9. so does anyone know the answer to my question. how do i tell if my idel screws are even on both carbs or does it not matter. my quad only stays running with them all the way in. and my others are 1.5 out. wirh the 48's going to try the 45's wendays when all my mains come in,
  10. i never pulled the clutch apart before. it was fine last time i road it with the stock cable. do i have to pull the pressure plate off or is it just the nut and screw thing in the center. also what way did u go to adjust it.
  11. I need a new cable so i got the stream line clutch cable. put it on the bike and i have maxed out all the adjustes on the bike and when i put it in to gear it still jumps and rolls slowley. has anyone had this problem and if so what did you do to fix it.
  12. different for sure but cool.
  13. that thing has been up idk how many times. first time i seen it was way before x-mass. that is for someone that would go and buy a t-rex to drive around the streets.
  14. ya i could use the help too lol. at least mine almost idels on its own now.
  15. Ok guys i got some jets in yesterday. i put 48 pilots in and it is starting a lot easier my screws are 1 1/2 turns out. idel screws have been played with a little but still wont idle unless i give it a little gas it slowly dies down. should i go to my 45's also stumbles a little. and i got 170 for maimns still just tryn to get it to idle would i be safe just tryn the 148. starts on like first kick sometimes second. and one thing i need to know how do you know if your idel screws are matching.
  16. do some search's there are efi kit's for banshee's and you can also buy turbo kits that ppl haev taken off there banshee once and a while on ebay. i was going to do it to mine but was not worth it to me. just going to do a 4 or 6 mil later on down the road.
  17. that looks sick. all most as birght as the ones on my dame car.i want some
  18. 40 is t-shirt weather all day long. and like everyone elsa said get it off the ground. and start banging away if you don't have a air chizle. it took me 2 hours to get my brothers out of his 400ex with a 5bls hammer. see if u can get some pb blast in the it will eat away at the rust some. but either way you got some banging to do if it is rusted in.
  19. i paid 675 for the ones on my shee.
  20. Thanks a lot i am going to call jeff tomorrow and get some 42,45,48 and 50's so i have them. and some mains. i haven't been using off sizes i have only tryd the ones i have and the are kehin jets just to big from what you are sayn. once i get the new ones i will try again. once i try the new ones i will let you know how it is thanks a lot guys.
  21. tourch it and i couldn't of said it better my self hope it is for a girlfriend or something. o going to need a chest protecter too for all the rocks. lol
  22. na i got the off ebay from carbpartsstore. they gave me some jets but not the ones i need. 55 and 60 pilots 170,165,155 mains
  23. looking for pilot jets for 35mm pwk airstrikers 40-50's
  24. ok i am going to get some more pilot jets don't have any that small.
  25. ok was just out side playn around with. the frist time i got it started it had this for jets pilots 55's mains 170's needle 3rd clip CGL i just tryd 60's 170's 3rd clip CGL and not i can't even get it to start has new plugs in it too. and jackson i can make it a little shorter i was bored
