Bansh-eman
Everything posted by Bansh-eman
  1. i dont run them and dont plan on it, ut they are not bad to have, like said that dirt or sand gets into your bowl from one spot.
  2. i was going to buy some jimmi jammers for my truck but i think im going to head to sears and get this, get my break bled and take it back then go get my jimmi jammers lol
  3. yea iv done this as well, i tried to get it to prime for a long time last night. i just cant get it to prime the lines. Once its primed it will be nothing its just getting it to prime with the two lines is a pain.
  4. already done it, couldnt get it to prime. i want to find an extra cap and drill a hole for a valve stem. that is the best way to do it, but with Pres weekend coming i might just have to break down and buy a mityvac. hell i can always take it back. U guys know if they carry it a walmart? then i can take it back when ever i want
  5. i think im going to remove the lower banjo and put it in the brake fulid and pump it. i have heard guys that where able to prime the lines like that. i tried the hose on the valve and it didnt help either. hopfully when i get home today the lines had enough time sitting open that fluid seeped down enough to prime it.
  6. Looking for someone in San Diego with a Mityvac or any type of brake bleeding vacume. I am having a hell of a time priming the front brakes so i can bleed them. Let me know if you got one. I left the valves open all last night and there was fluid that made its way down but i think there is still a pocket of air at the top keeping it from catching.
  7. banshee doesnt use a case spliter. the halfs just lay together horizontally with silicon to seal them. you might be able to split the case on the blasters without it, give Kevin at Herr Jugs Racing a call, his wife has a blaster he might know of a way to seperate it without the tool.
  8. or try calling either Eibach or Works. they should be able to tell you what spring to get. you should have your shock revalved for your weight aslo. the spring alone isnt going to help you all that much
  9. glamis
  10. longer swinger
  11. you talking about the nut on the crankshaft or the nut on the puller its self?
  12. nice loking gun, good luck with the trade. this croud doesnt seem to be into paintball much. i had an Angle with alot of shit that i was looking to get rid of back in the day and not a single person was interested in it
  13. iv got 97% of my bike back together. i'll be riding on my new Wickeds on Pres weekend. Although mine are not going to glide over anything cause im running marvins and they were supposed to be hillshooters, sent them to yanell to have cut and come to find out they are comps. so my shit is goingot be bouncing around like crazy
  14. ill say it again, take picts of the metal. if its just shaving its from your clutch
  15. yea reno 911 is fuking funny! check this one out
  16. nothing goes there. it actually gets covered by the gasket when the cover is on. not sure what the intention was of putting it there. take some picts of the metal your talking about.
  17. without a dought, steve is a good guy. he wouldnt jerk you around
  18. im not a fan of how they stick out the front on the top, but they look good. try taking a heat source to those stress marks and try to lighten them up.
  19. now that i think of it, i had the spring on a +4 swinger at 180. but it ould still be to soft for you i think
  20. no it would be too light for you. i ran that spring when i was 180 lbs on a stock length swinger.
  21. IMS Tank ( NO cap or petcock ) $175 Stock Coil $50 Lower Motor Mounts $15 Eibach 8 Inch Coil over Rear Spring 0800-225-0375, Used but good condition. $30 Brand New EK Non O-Ring Chain with Master link. Long enough for a +6. I think I counted 130 links. Brought this last year and decided to run a Sidewinder instead. $100 If you wish to use Paypal You add 3% for fees. If not I will take money orders. All parts plus shipping.
  22. http://www.bansheehq.com/forums/index.php?showtopic=86768
  23. if you where track riding id say yes but for dunes and all that i run mine at stock width. I have an RPM Dominator axle. got it for 200 off ebay used. it goes to like +4 but im running it stock
