ohiobanshee
Everything posted by ohiobanshee
  1. Most that I see run are Nitrous Express wet kits.
  2. x2 Also put a little grease on the other o rings to help hold them in place when you put the head on.
  3. Pull your carbs and see what size main jet is in it.If it ran better with the lid removed,your jetted rich.
  4. Call Jeff at FAST he can hook you up. Most places are between 2 and 3 dollars a jet. If you buy in bulk you might get a better deal.
  5. Tear it down and take the cylinders to a machine shop to be miked before you buy parts.It could save you money in the long run.I bought a set of cylinders off ebay that a wrist pin circlip had came loose,all I had to do was have them bored.
  6. Pm NYUK on here.
  7. 190-200 is stock.I'd start with at least a 270 and see how it runs.You are more than likely lean.
  8. The winner is sandman81,don't blame me wife drew the name.
  9. The front bolt pattern is the same.
  10. What the hell kind of motor do you have too need that long of swinger?
  11. Just put a new g force axle on my banshee. Sprocket hub was tight,no play in the splines.
  12. Make sure all the bolts and nuts are off.
  13. Not sure,bought them a while ago from Nacs.
  14. Price on the brake light switches.
  15. I had a girl give me something free once,AJAX wouldn't get rid of that shit. :yelrotflmao:
  16. The first traffic light you come to before maysville,turn left thats the only way you can turn.It's Clyde Barbour HW .Follow it till it ends,across the bridge.Turn left on rt 52,as soon as you turn on 52 you will see a bowling alley on your left,I live between the bowling alley and the school.I am the only place between the two. If you come up 52 as soon as you pass the bridge i'm on the left.
  17. If your still having trouble,bring your bike to me I will help you fix it or at least tell you what you need to get it running.I'm 60 miles east of cincy on rt 52.
  18. What way are you guys coming,52 thru Ohio,or rt 9 thru ky?
  19. You guys that are coming Friday can stay in my backyard if you want.I'm 10 minutes from there.Backyard is about 2 acres,plenty of room for your trucks.
  20. Just got mine from here http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=140325005890
  21. Most likely it's the carb top seal,under the cap you screw on top of the carbs.
  22. It tells the bike when to fire.
  23. Yes,you have two tabs on the flywheel,you measure between the tab and pickup.
