375hp banshees
    209
Everything posted by 375hp banshees
  1. You're not even PFC anymore Sent from my XT1585 using Tapatalk
  2. Always consider the source...just sayin
  3. ^ definitely not a captain^ Sent from my XT1585 using Tapatalk
  4. ^^ Sent from my XT1585 using Tapatalk
  5. Google p clamps & take a pick
  6. Not everybody licks butt holes...that's an Oregon thing
  7. Umm... I don't know about in Michigan, but we don't talk like that to guys in Florida[emoji3590] Sent from my XT1585 using Tapatalk
  8. I'd hook a small hose to a shop vac 1st, then I would turn it on it's side or upside down & strategically spray with an aerosol cleaner/oil with hose, as not to push it towards any bearings. You could vac. while spraying too I wouldn't slosh anything around in there 'till you know it's as clean as you can get 1st
  9. If it was me , I would do a compression check and pull your pipes and see how scored your new Pistons are on the exhaust side when you do a compression check see how gray your plugs are too How much coolant did you have to put back in it to fill it back up? Sent from my XT1585 using Tapatalk
  10. It kicks over, just won't start when kicked? What are the "new oe cylinders" Yamaha or just not cp? are they niche? Re-check compression now Sent from my XT1585 using Tapatalk
  11. The way I read it rebuilt & ran good except trans got stuck in gear...took apart to change star & hasn't ran since so either coincidence and something grabbed out or something he unintentionally did while doing star? Sent from my XT1585 using Tapatalk
  12. Said he already did... I wonder if that sizzling sound was wires and not overheating? Sent from my XT1585 using Tapatalk
  13. I was just welcoming the newbs... Not us old motherfrs Sent from my XT1585 using Tapatalk
  14. Your a different kinda mother fucker...that doesn't count Sent from my XT1585 using Tapatalk
  15. Happy mother's fukr's day from da east coast! Welcome to da game boys: Kawa110 Lastnline75 Jesse Buck Cam Paymentplan Blacknyellowbanshee? Jd ( again) *Tyler *yours doesn't count ( #1's Greens & #2's the Dominicans) **Toeknee **you're a little slow... (gotya next year) Seems like I'm missing somebody ... HAPPY MOTHER FUKR'S DAY to you too Sorry Claude goats don't count
  16. That's a hard one , they make a tester that checks spark under pressure. I'd try to think of something you changed when you did the star, intentionally or unintentionally Your getting fuel, plugs are wet? Sent from my XT1585 using Tapatalk
  17. Only other two things are air & fuel .unless it's outa time or spark is weak
  18. Easy there cap toekneeee
  19. Lol that's what I did (kinda)+ I was having to stay high and hit the embankment... wasn't pretty Sent from my XT1585 using Tapatalk
  20. Yeah last time I went , was on a local speedway track and speedway guy wanted me to stay high as not to mess up his good line with my nobbies ...I ended up in the hospital Sent from my XT1585 using Tapatalk
  21. Need more info...Browse through here, every motor is different my stock carb'd with pipes & pods was 340 at sea level ,most are around 280 to 300
  22. If by dirt tires you mean knobbie style, Some tracks won't t let u run knobbies, better make sure before going/ buying tires
  23. Wire ends?, Got spare cdi Anything new since rebuild ( elec wise)?
  24. https://farmandsandtoys.com/ocart2/atv/yamaha/banshee/shift-fork-1.html?limit=100 https://farmandsandtoys.com/ocart2/atv/yamaha/banshee/shift-fork-2.html?limit=100
  25. Got Air,Fuel, spark( timed), leak down tested?
