375hp banshees
    209
Everything posted by 375hp banshees
  1. Since AC is so finicky with them, might want to check them on a battery for diagnosing. iirc theyre polarity sensitive Sent from my XT1585 using Tapatalk
  2. You'll have to pull the flywheel & float your ground also to do DC Sent from my XT1585 using Tapatalk
  3. Don't see why not, Helicoil it if it's not to wallered out Sent from my XT1585 using Tapatalk
  4. Lectron Sent from my XT1585 using Tapatalk
  5. Yes, so pipes don't crack Yes, everydody talks highly of the DRW case savers? think it's Weston rainwater on FB? Sent from my XT1585 using Tapatalk
  6. Don't forget pipe hangers and case saver Sent from my XT1585 using Tapatalk
  7. Iirc usually 1-1/2 turns on air( if jetted correctly) if to far off of that rejet. Set idol to your preferred rpm usually checked with vac. Gauge/ Sync tool to make sure they are sync'd Some set idol with cable & some with screws. then check sync. again at higher Rpms ( or sight in the windows @ wot ; off) to verify sync. Sent from my XT1585 using Tapatalk
  8. Is there another adjuster @ the Y ? Sent from my XT1585 using Tapatalk
  9. Edited.... Different Sent from my XT1585 using Tapatalk
  10. He got different tires Claude...fyi Sent from my XT1585 using Tapatalk
  11. Cuz you left him hang'n Sent from my XT1585 using Tapatalk
  12. Fast told/sold me longer ones with my 35's I got from them Sent from my XT1585 using Tapatalk
  13. That's what I assumed , but I didn't want to guess, since he had to order something... didn't want him to order the cable also, and find out he needs the longer adjusters and have to wait again. Sent from my XT1585 using Tapatalk
  14. I wouldn't order anything from vitos... Call f.a.s t. & See if they will answer. I would try to find out for sure, before ordering anything Sent from my XT1585 using Tapatalk
  15. That might not be the case, just throwing it out there Sent from my XT1585 using Tapatalk
  16. The only people that would know that are people that have went from lectrons to keihin before ( and a knowledgeable carb seller) but he probably didn't know you were going from lectrons to keihins so... Sent from my XT1585 using Tapatalk If that's the case I, haven't done that myself
  17. Does the ball fit in your slides? I know you can't do that via that insert but Sent from my XT1585 using Tapatalk
  18. did you buy a cable with the carbs or that's the one that was on the Shee with lectrons? If not, I'm assuming, IDK for sure? Sent from my XT1585 using Tapatalk
  19. I'll bet the electron cable is different than keihin, call cam. n ask Sent from my XT1585 using Tapatalk
  20. You'll have to do some more digging the lectron cable might be different than keihin? But I believe typically, you also get this adapter in a longer version to take up more slack ? Sent from my XT1585 using Tapatalk
  21. iirc most of the time the carb seller advises you to get longer inserts ...iirc Sent from my XT1585 using Tapatalk
  22. If that's not a plastic case saver, you better take that off . looks like it's too late anyway but, to prevent a major next time! Sent from my XT1585 using Tapatalk
  23. See what they say, but I would think an inch and a half sucked in on either side is quite a bit... Can't believe they don't offer more options Sent from my XT1585 using Tapatalk
  24. That's a bottom end, not a rear end... you perv Sent from my XT1585 using Tapatalk
  25. Sorry toeknee, for those in Flint... there are knurls on the handle bars. the measurements are: Two and a half inches Or Four inches From center to center of the knurls The above measurements of those knurls (on the ones I have) are plus or minus, aka approximate, aka + - Are these bars year specific , or have I acquired some non banshee specific bars? #flintlivesmatter Sent from my XT1585 using Tapatalk
