woodro77
Everything posted by woodro77
  1. i just did my motor and a shop charged 300 for boring both cylinders, complete gasket set and weisco pistons , rings , wristpin bearings
  2. doesnt look like detonation , looks more like something came loose , piece of ring maybe.
  3. i just bought one and installed it, it came with every thing you need, spacers , nuts , and lock nut.
  4. i have a craftman compression tester and it works perfect. my friend brought his snap on tester over and we did a comp test with both and my craftsman was right on the money with his snap on.
  5. a screwdriver or a punch just kidding , never seen a tool made for that
  6. i have the Thor and like it very much (saved my ribs a couple times) if i were you i would try on as many different brands as i can and see which fits you best , everyone's body is different
  7. if your talking about the rear chain guide, i would keep it on, it guides the chain onto the sprocket ,ever see what a chain that jumps off the sprocket does to you engine case, they are like 12 bucks new. if your talking about the front it stops the chain from rubbing on the swing arm i dont see why you wouldnt want run them
  8. just got all my parts for new top end and now i want more power,(did not install yet) thinking about sending my cylinders to passion for 12 port, do i need to get the 4mm stroker ,how much more power with the 4mm? i already bought wiesco pistons and bored my cylinders,with 4 mm i will have to get new different pistons, is the 4mm worth the extra money , i also saw the vito stroker , what is the difference between the hot rod and vito, vitos told me that i can run the pistons i already have , would just the 12 port alone give me alot more gains, also does anyone know any shops in NEW YORK that does porting? any help would be appreciated
  9. could be wrong size pistons for the bore
  10. thanks
  11. dunlop 756 , or michelin starcross mh2 kick ass , i race mx and i use both,
  12. can any body tell me what brand these +2 a arms are, or where can i get new ball joints for them
  13. when you bring your banshee to the yamaha stealership for tranny work make sure you lube your ass up because they are going to fu*k you.
  14. i think that was my wife
  15. but they also say when a product is a piece of shit
  16. transworld mx mag tested it and said the i cat is a very good product and worked very good ,i put one on my cr 250, when i put it on i did alot of other work, i should take it off and see if i can tell diffrence .
  17. 35MM KEIHNS
  18. THIS IS MY CR 250, IM 6-2 230 AND IT PULLS ME AROUND REAL GOOD,SELLING IT THOUGH ,BUYING NEW CRF 450 TO KEEP UP WITH THE 4 POKES AT THE RACES, JUST EASIER TO GO FAST ON 4 POKE.
  19. ARE THEY ANY GOOD?
  20. what kind od reeds are these, the intakes and reeds dont come apart looks like one piece or glued?
  21. search j arms under atv parts on ebay, you wil see them
  22. why dont you buy a frame and just get it powder coated your self, then it will be like brand new.
