ozosborne
Everything posted by ozosborne
  1. Damn! I would not be happy!!!
  2. If it was real then you would have a slight problem on your hands!!
  3. I changed all of it to YFZ.
  4. Im running 4mm crank with blaster pistons. I have a pro design cool head with 17cc domes on. They did touch slightly, I just had a base gasket made. As far as I remember the ports lined up perfect.
  5. I've got the pro taper mid bar. It would depend on how tall you are. My rule of thurmb is that your arms are not higher or too much lower than your shoulders. This seemed to help me with arm pump, with my hands about 10cm lower than my shoulders.
  6. Should look very nice!! :beer:
  7. :yelrotflmao: :yelrotflmao: :yelrotflmao:
  8. I looked into Nitrous a while back and found a kit built for the shee from NXpress. Not sure if you have them that side! :ermm: They had a 60hp kit!! :shoothead:
  9. The 07 is already available here by us. It's identical, just red and black! :beer:
  10. Those are some really nice pics!! Sounds like your shee is gonna look sweet!! :beer: :beer: :beer:
  11. So he finally got hold of me and the shipping sounds very reasonable!! :biggrin: Just waiting to see what the total price will be and I should be putting in the order! Is that coating on your domes similar to powder coating?? Seems like a good idea. What would the diffs be on a noss machine head vs lets say a hemi head?? :ermm: Thanks for all the advice, must make sure I'm going the right direction with the mods. :biggrin:
  12. Fitted the vf3's last week and tested them out this week end. They are awesome!! :beer: Took over a second off my lap times!! :biggrin: :biggrin: :biggrin:
  13. Thanks a lot man, I'm really keen!! :cool: You can e-mail me on [email protected] or just pm me on here! Thanks for helping out guys. :biggrin: Stupid question: Are the noss heads ported?? I want to run 19cc domes so that I can run 102 octane! :beer:
  14. Anyone know how I can get hold of the guys from noss machine? Sent them 2 mails and no reply!! :: I want to get some of their goodies. :biggrin: I need to know what shipping is gonna run me to South Africa?? While we on the topic, anyone running their head?? Would like to know what they like. I'm keen on a head with 19cc domes and the o ring set. Appreciate anyone's input! :wink:
  15. Thanks for the replies. Will prolly do it then, it's worth 2 hp. :biggrin:
  16. Was thinking of using a stainless steel grinder blade. We use the same blade to cut ally plates at my factory. Also cuts through mild steel like butter and leaves a nice smooth finish. Will probably do it over the december period, will def post some pics here. :wink:
  17. Awesome write up man, I have a set of re valved 450 shocks already fitted that I picked up real cheap. Now I have a perfect set of 450 a arms and tie rods for free, been thinking about doing this for quite a while now. One question though, how does the location of the grease nipple sit now? Does the grease still stay inside? I was thinking of just welding the part that has been cut off back on the other side, what you think??
  18. Hi guys, how often does one have to change the packing on the silencers, and also what are the losses if not changed in time?? Just started racing flat track, done about 5 races and it's awesome!!! :cool: Finally getting vf3 reed valves!!
  19. Agreed, it is their own fault, we getting increasing pressure over here from these hooligans all over, varying from stone throwing to stringing wire across roads at neck height! Opportunistic f*ckers is what they are, anything to get a few rands!! Lesotho unfortunately is home to one of the biggest events here, "the roof of africa" a gruelling enduro!!
  20. Check this crap out guys!! http://wilddogtours.co.za/forum/viewtopic.php?t=1149
  21. Sounds like you got quite a ride there! Seems like after much talk and debate I will end up going for the Vforce 3's. Just damn pricy though! Cost like R3000 (RSA) here! Will have to save for a while I guess!
  22. Sorry if I'm missing it. I've searched and the info there is minimal. Plus the links are not working( i.e. Cannot find server) If you have found it,please post the link!
  23. I've searched quite a bit on here and can't seem to find decent info,One question I do have though, can the stock reeds still be used?
  24. My 0.2c 1. Nerf bars 2. Pipes 3. Filter 4. 450 shocks 5. Spacers
