orangecrush94
About orangecrush94
  • Birthday 02/07/1965
Contact Methods
    South Dallas
    94 new crank new pistons 20 over cool head 19 cc domes noligy coil port and polish from passion trinty 2 into 1 35mm carb t-dub plus 4 swingarm g-force axel new bars new plastic.99 banshee 4 mill in the works
orangecrush94's Achievements
  1. Well the motor has new crank new seals new pistons 60 over passion port ,coolhead 19cc domes,booneman lighnted flywheel,nogily coil. new 28mm carbs t-5 pipes.Also was thinking about going to cpi inframes, or outerframes just dont know.O-yea timming advanced 4 deg new cdi.
  2. Thanks for the all the replies,i was leaning towards boondockers myself.
  3. For a slightly modded shee,your basic port ,carbs pipes, and so on what would be the best nitrous kit to get dry or wet system. I was told to go with a dry 20hp shot.Any feedback would help.
  4. Magic racing.com
  5. I have been using the trinty 2 into 1,and now i am going with the 28 pwk.s .What i was wanting to know is a close starting point on the needle clip position and main.I am 60 over 19cc domes passion port ,and t-5,s lightned flywheel.Elevation is 600ft .
  6. If i am correct the stock plates come with those but the aftermarket clutches do not need them.
  7. I know dollars bike was fast,hell all craycraft are runners.It was nice meeting you and the family.
  8. Ice most people run pro wedges or holeshots not no paddels,glad you can make it.
  9. Hey icecold shee i have pretty close the same mods as you but i have a passion port and a few other things,and when i was down at the clash of the titans i had mine put on the dyno and we went with the 185 main 52 piolt and works great.hpe that can help....
  10. I need to try lake murray one of these weekend,s. just to try it out,anyway pm me sometime and we will hook up.We will be at little sahara for the races may 6th.
  11. I have some thing,s to do sat,but sun a few of us are heading to rocky for a little racing.I know dollar will be there from 14min.com me and my brother in law, and my 2 brothers and some friends that always show on sun.So if you can swing on down. Thanks for the offer on sat.......
  12. I have a singel 35mm carb pwk, and need to know when you turn the carb over should the float,s be level across or what............
  13. Went to clash of the titans and had the shee puy on the dyno,we lowerd the clip from 3rd to 2nd postion,and we went from a 185 to a182 main.Now i get back home and we went out to a riding area and starting racing .I would take off in 2nd and hit 3rd and then when i hit 4th and 5th it started boging.It wil only do it in 4th 5th gear.The motor is new new crank wiseco piston 20 over 19cc domes dune port by passion t-5 pipes lightened flywheel.trinty 2into 1 35mm carb v force 3 reeds
  14. We will meet you out ther if you go to rocky.If you come we always park on the drag strip,we will have 2 banshee 1 yfz 2 raptor1 is a craycraft 740 cr250 maybe more just look for a orange and black banshee and that will be me stop by, later...
