trickedcarbine
    165
Everything posted by trickedcarbine
  1. Side pic of the logo, and get photos of the intake, the transfers on the bottom, the ports from the top down and a shot of the exhaust. You mentioned you got a head with it. Are the domes stepped? It would help you know if ya 4mm or not. I believe that is a 65mm piston as well.
  2. Local guru is probably a lil nuts. + 8 is a bit much for a build like this.
  3. That's borderline premium. If you give it timing and have a fairly tight squish clearance you may wanna blend fuel or see if you can find 98 anywhere.
  4. Right on. Good catch on the bogus sealing surface on the manifold. Easier to do what you did then to rebuild a motor because some jaggoff can't handle a flap wheel.
  5. Running a motor with to much octane won't hurt it, but performance would be down if the motor truely doesn't need it. If the motor isn't making a lot of compression or isn't using to much timing, the fuel won't all light and burn completely. When you could potentially take that same motor and feed it premium and actually have a better output then it would on race fuel.
  6. You expect me to believe you get all that doin' tune ups and selling sandwiches?
  7. Working prototype Yes. Functional plug and play kits Fail.
  8. 34's could suffice. I would run them and if you're not happy try the 39's. Not worth the chunk of change going from 34mm to 35mm. Plus the cost to convert to alky on another set of carbs.
  9. Nah. I'll come hang out with you and lacy when I'm ready. I told you that already. We can yell out Eiffel Tower when we tag in.
  10. Now that guy is a freak. Whattya doing on Thursdays?
  11. You two would make a seriously legit couple.
  12. RaceLogic
  13. I think he posted it for Larry's shee somewhere. It wasn't long ago. I'm not lookin'.
  14. What was it mixed at. The dominator really ain't for 32:1 mixing, especially is a safe rich set up.
  15. 50:1 is just fine if the oil you're using is designed to do so.
  16. My first built motor was a runner too. Then I figured out just because what I have is ok, doesn't mean there isn't way better out there.
  17. Mattoon got your parts going?
  18. seems everyone assumed it never worked since he didn't post it here. The info has been posted if you know where to look.
  19. Meh, go be depressed else where and comeback when you need a good laugh. You really can't leave for good. There's no way the fucks at the dealer will help you with your banshee.
  20. Wow, that's brilliant.
  21. First sentence is the most ironic thing I've seen today.
  22. Absolutely. There's a few good conversions here and the RZ forums. Google usually works better as a search then the site search. Try " (topic) bansheehq"
