jmoore
Everything posted by jmoore
  1. Lol Thanks guys. When it comes to put the hubs back on, these will stay off.
  2. I took my hubs off to get powdercoated. I'm just wondering if these parts can stay off. It would definately get rid of some uglyness. http://
  3. I am going to pick up some new bars within the next week here and also get the trail tech big bar clamp kit. Which bend would keep it around stock height? Mid or high bend? Would you guys reccomend the cr bend or the atv bend? I see that these are the most common but im not really sure of the difference between the two. The bars im looking at are the pro taper contours or the trail tech x bars. Thanks
  4. Sorry, t.o.r.s has been removed so yeah I need a cable for stock carbs with the tors removed.
  5. A buddy is in need. Let me know if you have one laying around. Thanks For thumb throttle
  6. After 4 years on my stock chain, I am going to get a replacement. I believe a stock replacement would be a 520/104? I want to mess around with some different size sprockets like a 15/40 or maybe try a 14/44 setup. At what point do I need a different length chain? Also I would love to have a roundhouse style carrier. These dont fit on the stock swinarm right? After doing some searching, I am under the assumption that you need a new swingarm for a round house? Thanks!
  7. Thanks for the input guys! I will prolly get the 4 snows and put tubes in them. I have read a few comments from people about them coming off the bead on occasion. J-Madd - Is that your Challenger? Very nice!
  8. I have been wanting to buy some tires for the snow. Leaning towards the 4snow's but I was just wondering if regular sand tires would work? I would really like to stay with a 20" tire and all those snow tires only come in 22's.
  9. '04 factory frame
  10. Are you using stock length shocks? I have been looking at those same arms but I wonder how the ride would be with my stock length works shocks.
  11. Just wondering what the actual dimentions of the basket are. Can someone measure theirs and tell me what brand you have? Thanks!
  12. I just replaced my stock carbs with a stage 5 2 into 1 setup with a 33 pwk carb. Had some problems getting it dialed in this weekend. It runs awesome except at low throttle. It is loading up bad. I have a 170 main, DEK needle with the clip one up from the center, (leaner), and I have gone down to a 35 pilot. As low as I can go. I tried adjusting the air screw but had no luck. It really sputters at low throttle and my left side plug will get very wet, as well as my left side exhaust pipe. Why would one side load up like that? I bought this setup used so i'm wondering if the slide is shot or something.? My plugs are dark brown and also the one left side is very wet. I have now done everything I can think of to get it running right so I am looking for some new suggestions. Also, I started out at a 50 pilot and went down from there. It really ran like shit with the 50 in. I would also like to add that on a cold start it will rev up very high for a few seconds before it idles down to normal. Elevation is at about 1200 give or take a little. Other mods should be below. Thanks in advance for any help
  13. Looking to trade straight up. I have some Tusk nerf bars and want to trade for some stockers. They are anodized red and have a little wear on the backs from having a passenger as seen in the pic. I need a full set of stock nerfs with the back blask plastic pieces. Must be in good shape. Send me an email if you have something. [email protected]
  14. Say hi to Sammy for us! Actually, I think he is on tour now but ya never know.
  15. Cruisin down a fireroad doin about 40. Came up quick on some ruts and didn't see this nice mound of dirt piled up in the road. Hit it square and got bucked off like like a damn cowboy on a bull. Ended up slammin to the ground on my back. Smacked the back of my head hard and slid about thiry feet down the road. My shee never left its tires though. If I didn't have my lid on who knows how I would have ended up. Anyway, my helmet shows no damage but I have heard from many peeps that you should replace it if you have any kind of impact. What do you think? Should I get a new lid?
  16. Your gnarlys are definately a low end pipe but if you gear up a little you might just pull away down the stretch. What is your gearing now? Vforce reeds and a coolhead are low end mods as well. They will smooth out your powerband and give you some added low end torque.
  17. Correctomundo tors are on the stock carbs
  18. Thats what I was thinkin...Please, no offense but, where did you put that extra cash?
  19. I say let them come in. And Lets all move to Mexico! NO more snow!!!!! whoo hoo But seriously, can you really blame illegals for wanting to come here? Look what this country has to offer. It's too bad most of us don't take advantage of it.
  20. Attached to your carb tops and cables, in your slides. You need to bring the springs up out of the slides and unscrew the assembly that holds the needles in. Kind of a pain but not too bad. Hope this helps you out. Dont drop your needle on the ground and bend it like I did
  21. I saw that too.. I was thinking how good that seller feels right about now! People are dumb sometimes.
  22. So you broke the nut? Or the stud itself? If you only broke the top of the stud off just take it out and replace it...? Either way, sounds like an eazy fix.
  23. Your fluid is pink/orange? I would drain it and fill it with the green 50/50 mix stuff. Yes, the same antifreeze you put in your car.
