sheerider11
    107
  1. Send your motor to a builder. Tell them you want 1200 worth of speed in your motor
  2. I get that. But get more "spending money" to get shut that's worth it. Instead of 200 get 2000. Build yourself a 4 mil that'll hold you over. Save up another 2k and get suspension
  3. Put it in a bank and keep saving
  4. I don't know I had a 97 cr250. Bike scared the piss out of me more then a few times. Before I went 4 mil I was willing to put money down that my cr was way faster then my banshee. The torque that the bike mad was what made it so scary
  5. I like the grey the old school sponsor shirt is. With the graffiti logo on the front
  6. They look good. I like the colors. I'm just thinking now of people asking what's " ride WF" mean? I don't know how many people will associate the logo with an O. But regardless I'll prob get one. Just throwing ideas out there
  7. I don't know. The O isn't either needs to be the color or a real O. And that box won't be around it right?
  8. No RTV. I put a nice coat of white lithium grease on both sides of the gasket
  9. One wire is grounded and the other can be connected to the black and white wire that goes to the on off switch. I tied mine into my coil and it grounds it there
  10. If you pull it the bike shuts off. So you attach it to you so if you fall off the bike it'll shut down. Itncan be used as a key
  11. Do it. Get a tether. Clean up the harness and be done with it
  12. Do your self the favor now and ditch the Hinson plate and bushings. I ordered a plate and bushings and bolts from cam at redline. The Hinson bushings are to soft and they expand and press against the backing plate. This bends them. It eventually bends the plate far enough to pop a head off one of the nuts and then all hell breaks loose from there.
  13. I just put one on my bike 2 days ago. Fits fine. It won't be any cooler. But looks way better. Where do you ride? What kind of load is on the motor? How fast do you move? If you climbing hills and weaving between trees going slow, if expect your engine temp to go up. But if your ripping down a straight fire road, you could expect some lower numbers.
  14. What was this check for??
  15. That ain't so bad. But before you go and jet it, what your rad look like? Does it have sufficient air flow? Is your pump all good? Not chewed up broken fins? No point in jetting if you can't get the coolant to dissipate the heat through the rad.
  16. By Joe Bond - September 7, 2012Amazon Verified Purchase this inexpensive gadget allows more air intake right off of the line. what a great idea. This product is probably the most effective hp booster available at this low cost Awesome.
  17. Hmmm
  18. Yup. I never thought about it you guys not coming here. But now that you are it's like oh shit. I haven't had a bad cascade part yet
  19. It says alba pro elite. I'd start there
  20. Fixed it for you
  21. Okay I didn't read through. Is it a 4 mil port? Contact some one for 4 mil domes. Preferably the person who ported it. They'll know what domes work on there port
  22. Don't pick a piston size. Go to the next needed size. No reed spacers. Get it ported for the 4 mil. Get the domes for the 4 mil.
  23. All cpi are stamped. Older ones are stamped on the inside. Even older ones aren't stamped at all.
