dburnexx
About dburnexx
  • Birthday 09/12/1990
    Elkhart , Ks
  • Interests
    Dune trail riding, hill climbing, Jumping, and A little Dragging
Contact Methods
    1999 banshee red, black and yellow 392 serval Cylinders ported by Jeff at F.A.S.T Racing stock carbs v-force 4 reeds Toomy t5 pipes and silencers Fast head with 24cc domes hot rod stock stroke crank Fast clutch with heavy duty springs over sized radiator k&n POD air filter Alba Long travel suspension with fox podium shocks TC rear shock modded shift star Modded shift shaft Shift spring mod
Recent Profile Visitors
1,344 profile views
dburnexx's Achievements
  1. Ok I was told if I used it it would make my clutch slip so I didn't put it in the new basket
  2. It's a washer between the stock clutch basket and the retainer plate
  3. I can't up load pictures I put it on the fb page
  4. Do I need the spring washer for the new basket
  5. Try driving an hr to get it during the work week that's why I went to a set up on pump gas it's a pain in the ass to get in my area
  6. Got an email back from Jeff and I found out that I need +4
  7. Yea it's a trail bike and I wanted something reliable in the 70 hp range on pump gas so I can afford to ride a lil more.
  8. Ok ill leave it at 0 for this weekend until I can get a hold of Jeff
  9. Yea I am building it this weekend and would like to hear it run but forgot to ask what timing to run and he's not going to be around this weekend so I was going to copy a set up that was Close to mine till Monday and I get ahold of jeff
  10. I am curious what timing are yall running on your servals?
  11. I will post the dyno when I get it done a couple weeks from now but Jeff said ill be in the 70s on pump gas running t5's and stock carbs. He said that they have been getting good results with t5's on the 392. Im excited to get it built its going to be 100 % better than my current setup.
  12. Yea jeff from F.A.S.T. Racing hooked me up with the full setup and even did alil port work on the cylinders. I should have everything I need. I should be looking for mid 70s hp wise.
  13. Thanks and I already bought the 392 I'm bout to put it together this weekend
  14. I am building a serval 392 and curr ently have toomey t5s. I am alil concerned about not having a big enough stinger. I am building it for trails and sand hill climbing and need a lot of bottom end but still want some good top end I don't see a lot of discussion About the stock stroke serval. Thanks
