sheefreak
Everything posted by sheefreak
  1. It ran ok before you washed it, or is this a rebuild w/new mods?
  2. Do you have the tors system on it, if you do, try disconnecting the tors unit and see what happens.
  3. Will be on the lookout at Silver Lake this year, good luck!
  4. Will it rev if you give it gas?
  5. If it is real oily it has nothing to do w/your rings, they don't seal oil. Is it just comeing out of you right side(throttle side)? If it is it is probably your right side crank seal. If this seal is bad, it will suck tranny fluid and blow it right out your exhaust.
  6. I hope you are joking.
  7. Start w/some PB blaster penetrating oil.
  8. Lose power w/reed spacers? Could someone explain to me why?
  9. Price on NOSS head, and what colors, price on tie rods also please. Oh and price on billet round house carrier and if it is adaptable to stock swingarm. Also what size domes for noss head. Thanks, Damian.
  10. Just two words, HOLD ON!!!!
  11. Second that!
  12. If you are thinking of doing any racing, better go w/Banshee. Might as well completely forget about a blaster. Only problem is, depending on how much trail room you have, Banshee's can be a little fast for tight corners, especially for beginners.
  13. That Camaro is badass!!!
  14. Yes it can be done, is plenty of clearence.
  15. Get rid of it. Weight and another thing to go wrong on your much anticipated weekend out.
  16. Adding more premix oil leans out the mixture, you do not want this!!! Just run 32:1 or your preffered mix and like banshdog says, resist the urge. A class I took on 2 strokes suggests only half throttle for about 2 hours runtime. And easy warmup is crucial, especially w/forged pistons.
  17. I agree w/rnbrad. So many more Shee's have been produced and there are still plenty of aftermarket parts for the 250r.
  18. Jer, just unscrew the carb tops, the slide and needle will pull right out of the carbs, and you can leave the TORS system w/wires coming out of it connected to the frame, not difficult. Also, I have read that gas loses approximately 1 octane pont per month as it ages. You definately don't want detonation to occur.
  19. Any one seen the movie(documentary) Super Size me? Speaking of people that shouldn't be eating at McDonalds. You may never eat there again.
  20. Rod, thanks for the heads up, meant to say head, I didn't know if maybe they bored the valve openings larger and replaced w/larger valves or if this was even a possible procedure. I know if the valves were any larger, may need speacial pistons as the piston has a slight cutout for each valve.
  21. Need some suggestions for 4 stroke porting. Friend is trying to at least maintain sight distance w/me when we ride. He rides a warrior. Is willing to ship out head.
  22. What kind of reeds?
