87sheerips
HQ Site Sponsor!
    100
Everything posted by 87sheerips
  1. For the sealing surfaces, I like to use a 3M (scotch brite pad), about 1.5" diameter, on a 90 degree die grinder. This works amazing, but be careful and use light pressure. If you hammer down on it, you can remove aluminum material that could cause a leak.
  2. As far as I understand it, the o-rings replace the stock "stopper" pins that are usually in the bearings. Aftermarket bearings have o-rings to keep the outer portion of the bearing in place.
  3. Dont know yet, my buddy who does everything on my site needs to play with it.... Ill let you know! -JD
  4. Cool, cool... So will this work with my gas 35PWK's and/or Alky 34 PJ's?
  5. Ahhhh, I still have to find this grille i did for someone a while back.. here is a CAD model at least. PM me if this interests you
  6. Awesome! Hey I checked your site and am very interested in this new "venturi" filter setup. Can you delve into it a little more, as well as HP gains? I understand the CFM gains, but have you tested on a Dyno or anything at all? Even seat of pants? Thanks!
  7. Tim @ Stellarmachineandperformace.com
  8. I used to have the same exact pipes! They are awesome, and different for sure. They perform like T5's.. Great deal for someone here
  9. Awesome, I look forward to the installed pics!
  10. Thanks guys, the more the merrier! trying to deck out my website galleries with installed products. Thanks for the help, and look out for your machine representin' on my website!
  11. I Disagree
  12. Support BHQ and order arms from Stellar machine and performance. Top notch quality at a better price than any of the "mainstream" guys!!
  13. 1. Do a compression test to give you an idea on the condition of the top end. If stock(ish) you should see somewhere in the 120psi range. These testers can be found at Sears. 2. Stand up, grab the bars, and give the bike hell back and forth, etc... See where its loose. The front ball joints are a common failure part. Also the swingarm bearings and pivot tube see a lot of wear too. 3. Check the chain, and the engine cases by the front sprocket. There is commonly case damage here from a thrown chain. This usually does not leak, or cause further issues, but its cosmetically bad. Also make sure the chain tensioners int he back are in good condition. 4. Go over wiring and make sure nothing is hacked up. Check to make sure the lights and kill switch work of course. 5. Check air filter for proper installation. If there is a bunch of dirt in the carbs, for instance, I wouldn't want it! (Or hammer him down on the price lol) 6. Use common sense. Hang out here on HQ for a bit and do some homework. U can usually find a banshee on here to suit your needs for less than it would take for you to build one yourself. A lot of good deals out there and you came to the right place to begin your search! Welcome to the HQ
  14. Im pretty sure those are Trinity sparkies... They do make the silencers look like a big ole penis tho LOL
  15. Just ride it every week! Or, follow the above comments!
  16. USPS is the way to go! To ship from home, however, you need the special envelope to put the customs form into. There is 4 sheets of information that goes into the envelope, which you then stick to the front of the package. You can order the special envelopes from USPS.com or pick them up at your local branch office.
  17. Damn, now Im guna have to pull apart the trail bike for one of these!!! I have ragged on my drag bike pretty hard this season duning and dragging... No issues. Backloading, etc... It seems to be pretty durable and it is a WCR 1-5. My buddy (bansheefreak89) has a 1-5, neutral down that he got from dajojegr. He trail rides it, dunes, drags, etc... Without issue.
  18. Check out my auctions guys, have to get some parts off the shelf. get em' here cheap! JDs Customs on Ebay
  19. Fire that whore up and RIP!!!!
  20. Guys, just a note here that I make custom brackets for banshee's to stick these bad boys. PM me for details or check out "banshee accessores" gallery on my site!
  21. Just call Tim at Stellar and be done with it. best quality and least expensive J-Arms on the market for sure!
  22. Sweet, I have a Texas based grille designed up.. Ill try and dig up some pics for ya.
  23. Yep, everything seems good! I don't have a temp gauge so I cant tell you whether the temp has decreased.
  24. Those are sweet on there Dave! That mini is coming along, thanks for the pics brotha
