J-Madd
    19
Everything posted by J-Madd
  1. Yes. And clean up the dome as well. Sometimes I run the head and domes over a flat surface(marble,etc) on fine grit oiled sandpaper to resurface if there's a problem, but it may not be necessary. Do a leak down test with rad cap off and you should be good.
  2. 0.020" minimum and be done with it?
  3. I think the oring caused your issue, not the other way around.
  4. Water leak will cause deto. Fix the water leak and you should be fine. A leak down test can sometimes find a dome oring leak, but you need to make sure the radiator cap is off.
  5. What sprocket did you go with?
  6. On motor, PPS triple went 3.25 with like a 1.19 60' if I remember. K&T went 3.24 I think. Don't know that 60'. PPS triple is in Puerto Rico now. New build in progress I think. Those are both spread bores though. That was a Gilbert 2 different years.
  7. The aftermarket pancake bearing would not normally do that. Are you sure the clutch adjuster isn't stock? I've had a ceramic ball break and cause worse problems.
  8. Different builders set them up differently, but here are Calvin's specs. It says 0.022".
  9. ^^^^Yep. That being said, I have some flat top pistons that used to have a crown that I'm currently running in a Twister Sniper motor. Precision Powersports cut the pistons and designed the domes.
  10. Tranny was broke.
  11. Picked up a tenth on 421 Cub with staggered over straight. I see no reason to ever run straights in 300 ft. JMO
  12. Have you ran it since you fixed the coil wire? Maybe the plugs fouled when TORS took a crap? You already have some other troubleshooting tips covered.
  13. The piston speed is a lot higher with the 10 mil. With low port timing and this less RPMs it would last longer, IMO. Good to know you can run wot. I locked up 2 cubs like that, which I've mentioned before.
  14. At 100% volumetric efficiency at 10,000 rpms I come up with 37 cfm per cylinder, I don't know if the motor is more or less the 100% VE though. I also just used google to find these calculations, and I don't pretend to know this.
  15. It'll have power loss and cut out. Yes you can usually pop the clutch or down shift and run WOT for a bit to clear it out.
  16. If you mean ignition timing, it won't change. If you mean port timing, it has to be changed to accommodate the piston going 2 mm further up, and 2 mm further down.
  17. Clean the bore with brake cleaner before assembly.
  18. X2!
  19. Triple, 4 cylinder, car, I just want to see.
  20. At least 2 on 1st page in the swap shop that I wasn't too lazy to look at. Can't post link with tapatalk.
  21. I bet no time slips get posted here.
  22. NYUK is cool. And a good mod, I was just venting, I guess. These people whom I've never heard of and are doing this. They're probably not crooked ass crooks, but it's not that hard to post pics.
  23. Still have to port for 4 mil. Compression can be whatever you want.
  24. Just go to for sale section.
  25. Motor or nitrous? Asphalt or dirt?
