1800bigk
Everything posted by 1800bigk
  1. Yeah I still have them they are on ebay now. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
  2. No, I need money to help pay for my new stuff.
  3. They will clean up well if you use a scotchbrite pad and some elbow grease.
  4. deal, you have pm
  5. No, you dont need to go out and weld your crank right now. It is just beter to do that because all two stroke crank will seperate over time and the more power you make the more faster it happens. You can take your jugs off and measure the amount of seperation (if any) that you have. Use the clymer manual. I have buddies that have had even thier welded cranks seperate, it just the nature of two strokes. Measure your crank seperation, if its within limits then your good, if its out of limits fix it cause it can become problems down the road.
  6. not likely, unless it was an amazing offer that was hard to pass, but prolly not, I need cash.
  7. stock carbs off a 2003 a little dirty $45 shipped
  8. yes it has the long bolts yes it will fit 34mm carbs yes it has internal xover
  9. Sorry, they are no longer available.
  10. sold
  11. stock crank off of a running 2003 still has a lot of life left. make offer
  12. used boss intake $100 shipped. less than 1 month old.
  13. used v force 2's $110 shipped
  14. t-5's no dents or dings but they are rusty they need re powder coated.
  15. t-5's no dents or dings but they are rusty need re powdercoated. $175 shipped to any where in US
  16. Yes, I think you should definately be able to beat him. Race him on asphalt, if you still lose to him then dump more money into your engine, that always works
  17. my drain hole was plugged, it had a rock in it and a bunch of shit clogged it up.
  18. The plastic cover that covers the flywheel/stator only has a generic rubber seal on it. Can I use yamabond along with that rubber thing? When I pulled the cover off there was a water pool in the bottom of the cover so I know it leaks. I try to avoid water but sometimes I cant.
  19. I have my engine apart and my flywheel and stator are very rusty. The little black pick up thing on the stator has rust and the flywheel is covered in rust. the stator plate is corroded as hell too. My bike is an 03, should I replace thees parts? Could I get by with just a new stator and plate and keep my rusty flywheel? It looks terrible, I cant believe it runs. ps. is the ricky stator kit that cost $255 (flywheel, stator, plate) worth it?
  20. Is there any place to drag race quads in north east ohio? Its too cold right now, but I was wondering if there is any drag race scene at all in ohio or east PA? tia
  21. I ordered those needles last week, but it is -11 degrees here and way too cold to jet. I will try them when the weather breaks. thanks
