Manny's MX build
I don't want to agree with you..we are not talking about drag bike..as Tyler said depends on the set up..
Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
I was referring to shock length and placement, not traction.
A no link setup will always provide the most traction.
I still have that exact same magazine carefully tucked away in a big zip lock bag.
That was the primary inspiration for me to build my Laeger.
Because of this magazine i start dreaming and to be a owner of a banshee to...
  • Like 1
Soo...when the rear suspension is compressed from acceleration the shock angle actually helps keep the front tires on the ground where they can get traction and steer?
I am not seeing the problem.
It has to do with the result of the center of gravity forces..
On the stock frame the gravity forces are more front..on the Leagers Pro-Trax chassis the resultant of gravity forces causes the transfer of the center of gravity more rear..
  • Like 1
