njbanshee Posted June 5, 2008 Report Posted June 5, 2008 i think he would benefit more from porting than a coolhead. Quote
dekker Posted June 5, 2008 Report Posted June 5, 2008 Port it and have the head milled cant go wrong with that Quote
jamebo Posted June 5, 2008 Report Posted June 5, 2008 i think he would benefit more from porting than a coolhead. That's true, but he may be looking at some down-time with it being this time of year and being on a list. I was just throwing that suggestion out there as an option for a quick power mod. I'm wanting to get some porting done to mine but I'm going to wait for my first re-build when I have it all apart already. Quote
BellicoseBanshee Posted June 5, 2008 Report Posted June 5, 2008 cpi pipesk&n open air filters boost tube. vforce 3's. jetted for the open air filters. pretty much every thing you can do to it, with out turning a bolt the engine. Stock bore and stroke. stock pistons stock motor. You had to turns bolts to install reeds! :woot: You are on the original bore that is 7 years old, I would get the port job and a new top-end with it. Your compression might still be within limits, but it would be advantageous to do them at the same time. Bigger carburetors would compliment a nice port job and CPIs... If $500 is the max, shave the stock head, timing plate, and lighten the flywheel for now, save the rest for the port work and top-end. Quote
00tbanshee Posted June 5, 2008 Report Posted June 5, 2008 not sure what kind of riding you do but kevin's dune port is really nice.you can save your money by just having him cut your stock head.might be a good idea to have a fresh top end if its 7 yrs old.thats pretty much going to take up the 500 i believe.later on think of a adjustable timing plate and carbs but not a must if your not dragging it. Quote
