I got a 2001 shee. Every bolt on mod you can do without touching the engine internally.
I got 500.00 to spend.
What can I do for the most bang for my bucks.
ONLY 500.00 guys. thats it.
help me out. :beer:
So what are you wanting to spend it on the motor? If you got everything already that you can bolt on i'm taking it that you want to start doin some motor work?
yes, the motor.
any suggestions on who to send it to?
cpi pipes
k&n open air filters
boost tube.
vforce 3's.
jetted for the open air filters.
pretty much every thing you can do to it, with out turning a bolt the engine.
Stock bore and stroke.
stock pistons
stock motor.
Definitely send it to Herr Jugs Racing and get some porting. Tell him your riding style and he will set you up.
Porting, a top end kit, bore and hone would run you 500 or a little more maybe.
Next would be to get rid of your stock carbs.
thanks.
also, why do I need to remove tors. what is it?
TORS is junk and looks like shit on top of your carbs all they do is screw up your carbs. Get rid of the boost bottle it does nothing but crack your intake boots. go back to the stock crossover tube
TORS is a Throttle Override System that shuts your bike down if your slides get stuck
TORS is throttle over ride switch.
It's the big retarded boxes on top of your stock carbs. You can just unplug them and that will prevent them from working. They keep the throttle from sticking wide open, that's their purpose.
They make tuning a pain, and are in the way ALL THE TIME.
You can get a TORS delete kit that comes with the non-tors carb caps, new throttle cable, and idle screws for which you have to drill and tap your carbs...
