Gurnzz Posted May 22, 2008 Report Posted May 22, 2008 i wanted to know if a adjustable timing plate and a fly wheel degree key would be a good investment for a stock engine. as far performance is concerned, will this cause overheating, what kind of fuel should i use,octane? any info on this would be a great help. thanks so much! Gurnzz Quote
locogato11283 Posted May 22, 2008 Report Posted May 22, 2008 you will notice a gain with advanced timing. the plate it a better route to go. degree keys have been know to shear off causing problems. with advance timing you will need to run a higher octane fuel. a 50/50 mix of pump and 110 should be fine for a stock motor with advance timing. Quote
Gurnzz Posted May 22, 2008 Author Report Posted May 22, 2008 you will notice a gain with advanced timing. the plate it a better route to go. degree keys have been know to shear off causing problems. with advance timing you will need to run a higher octane fuel. a 50/50 mix of pump and 110 should be fine for a stock motor with advance timing. what company should i buy the adjustable timing plate from? thanks for the advice locogato ! Quote
locogato11283 Posted May 22, 2008 Report Posted May 22, 2008 what company should i buy the adjustable timing plate from? thanks for the advice locogato ! call Jeff @ FAST.. 1-785-354-5325 or PM him here on HQ at "FASTOYS". he will have everything you need and then some. super cool guy and will take care of you. Quote
Animalman294 Posted May 22, 2008 Report Posted May 22, 2008 i wanted to know if a adjustable timing plate and a fly wheel degree key would be a good investment for a stock engine. as far performance is concerned, will this cause overheating, what kind of fuel should i use,octane? any info on this would be a great help. thanks so much! Gurnzz Loco is right about the plate. The keys are cheaper, but you could pay a dear price if it fails.............. Quote
jbooker82 Posted May 22, 2008 Report Posted May 22, 2008 Chariot Performance sells a billit one for a few bucks more than the 35 dollar cast aluminum ones on ebay. Billit is the route I would go. Quote
Gurnzz Posted May 23, 2008 Author Report Posted May 23, 2008 Chariot Performance sells a billit one for a few bucks more than the 35 dollar cast aluminum ones on ebay. Billit is the route I would go. cool thanks for the suggestions. i will definently get the plate rather than the key. thanks again to all that replied! Quote
