i wanted to know if a adjustable timing plate and a fly wheel degree key would be a good investment for a stock engine. as far performance is concerned, will this cause overheating, what kind of fuel should i use,octane? any info on this would be a great help. thanks so much! Gurnzz
you will notice a gain with advanced timing. the plate it a better route to go. degree keys have been know to shear off causing problems.
with advance timing you will need to run a higher octane fuel. a 50/50 mix of pump and 110 should be fine for a stock motor with advance timing.
what company should i buy the adjustable timing plate from? thanks for the advice locogato !
call Jeff @ FAST.. 1-785-354-5325 or PM him here on HQ at "FASTOYS".
he will have everything you need and then some. super cool guy and will take care of you.
Loco is right about the plate. The keys are cheaper, but you could pay a dear price if it fails..............
Chariot Performance sells a billit one for a few bucks more than the 35 dollar cast aluminum ones on ebay. Billit is the route I would go.
cool thanks for the suggestions. i will definently get the plate rather than the key. thanks again to all that replied!
