pepehaha Posted February 22, 2008 Report Share Posted February 22, 2008 Hello, Iam rebuilding my shee. I have succesfully mounted LT aarms with elka LT shocks(quadrate), it looks supercool. But I have 3 problems with other mounting: Brakes I have installed extended break lines, filled the brake fluid in, ut the brake fluid still cant get throught the brake lines to the brakes Pipes - T5 I bought a set of used t5 pipes, but I have two problems with fitting them in: Firstly, the part 1 doesn't fit to the part two on this picture: http://rs259tg.rapidshare.com/files/93983780/2.jpg Secondly, same problem. The part 1 doesn't fit to the part two on this picture:http://rs259cg.rapidshare.com/files/93983781/3.jpg I would like to please you toadvice me Thanks! Btw: the pic how does it look from the front now: http://rs259cg.rapidshare.com/files/93983779/1.jpg (sorry for bad pic) Quote Link to comment Share on other sites More sharing options...
yamaha04 Posted February 22, 2008 Report Share Posted February 22, 2008 move the pipe around alittle. make sure its on the cylinders all the way. and lossen that mount so you cam swing it around and bolt them pipe to it whenever it lines up. Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted February 22, 2008 Report Share Posted February 22, 2008 I think the fitment of the t5s could be a little better also. If you can't get the stock mounts to fit, you could buy some aftermarket billet adjustable ones for about $40 and it looks a whole lot better. As far as your brakes go, bolt everything up the way it is supposed to be. Fill the resivore and crack both of the bleeders. Keep an eye on the fluid level and keep it full for 10 min or so. Shut the bleeders off, put the cover back on and give it a try. Let us know how it goes for ya. Your machine is looking real good man, and your screen name is pretty dam funny too! Ryan Quote Link to comment Share on other sites More sharing options...
theshee Posted February 22, 2008 Report Share Posted February 22, 2008 Loosen that mounting bracket and turn it down so the it lines up. The mount is just way to high for any aftermarket pipe. Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted February 22, 2008 Report Share Posted February 22, 2008 I just noticed your silencer picture. I think your gonna need a rear hanger of some sorts. I don't think you want to mount it directly to the frame. Here is a pic of mine. Ryan http://i265.photobucket.com/albums/ii224/b...ck/DSCN0275.jpg Quote Link to comment Share on other sites More sharing options...
yamaha04 Posted February 22, 2008 Report Share Posted February 22, 2008 yeah forsure you need a hanger. i had the same problem and was trying to figure out why it wouldnt mount. i made mine out off alluminum flat bar drilled two holes in them and called it a day. lol just mess around with the mounts they will fit Quote Link to comment Share on other sites More sharing options...
pepehaha Posted February 22, 2008 Author Report Share Posted February 22, 2008 Thank you all! I will make some hangers... About the brakes... Please can someone describe tome what is "bleeder" and where I can find it? Iam sorry,my english isn't perfect and I cant find it in dictionary... Thank you! Quote Link to comment Share on other sites More sharing options...
pepehaha Posted February 26, 2008 Author Report Share Posted February 26, 2008 Hello again, I have succesfully mounted the piipes, and started the shee(great, runs), and I have to say it rocks! A little bit loud, but I have a hush kit The only problem are still the front brakes Could someone please write an how-to fr me? I know its a retarded question but I have never done it before:( And also, what is thee bleeder? A,B or something else? http://rs372tl3.rapidshare.com/files/95070707/brake.jpg Thank you very much! Quote Link to comment Share on other sites More sharing options...
yamaha04 Posted February 26, 2008 Report Share Posted February 26, 2008 ok the bleeder is B in your pick. open the bleeder on one side. let the air/fluid come out then close the bleeder. then pump the hand brake a couple times then get someone to hold it on and crack the bleeder again. let the air/ fluid come out then close the bleeder again. pump the front brake a few times then get someone to hold it then open the bleeder again. left all the air. fluid come out. keep doing these steps over and over again until you get no air and just fluid coming out. you will know when its good because when your holding the brake on and you open the bleeder it should shoot fluid about 3 to 5 feet. lol then start on the other side and do the same. oh yeah when you are bleeding the brake you need to keep and eye on the brake resovior make sure its full all the time. some people ahve a hard time bleeding the brakes so iv herd they just open the bleeders alittle bit and let the bike sit for awhile coule hours maybe even a day. this will alowe the fluid to run down the lines and fill the caliper itself and ussualy pushes out the air. Quote Link to comment Share on other sites More sharing options...
pepehaha Posted February 26, 2008 Author Report Share Posted February 26, 2008 yamaha04: Thank you very much! I will try that! Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted February 26, 2008 Report Share Posted February 26, 2008 Attach rubber hoses to the bleed fittings and catch the fluid in a bucket... Quote Link to comment Share on other sites More sharing options...
dragbanshee Posted February 27, 2008 Report Share Posted February 27, 2008 Open the bleeders slowly and very little, just enough to see fluid moving, hold brake lever till you snug bleeder back up. Just keep working on it , it takes forever to get air out of the new lines. Good Luck! Quote Link to comment Share on other sites More sharing options...
