im building a bike with no lights and i would like to get rid of the handlebar switch. im only going to be running a kill switch from the wires off the key switch. just need to know how i could hook everything up to run the bike without the light/kill switch. thanks for any help!
As long as you keep your key switch.....you can unplug the handle bar mounted light/kill switch. It actually sends a ground to the cdi to kill the motor when in the off position. I used to install a tether kill switch on all of my bikes as an extra kill switch, but your key will do just fine. :biggrin:
sorry to bump in but i want to do the same but i want the lights always on.. how do i do that?
You will have to decide if you want the low beams, or high, and also if you want the tail light on.
Your feed wire(power) is the Yellow/Red wire. You will need to connect it to the wires below to determine what you want on.
The Low Beam wire is Green
The High Beam wire is Yellow
THe Tail light wire is Blue
Example.....if you want the high beams and tail light on....connect both of them to the Yellow/red wire.
You can find all of these wires at the plug where your light switch connects in the front under your gas tank cover.
Make sure to make a nice clean and somewhat water tight connection.
