nitroburner13 Posted November 18, 2007 Report Posted November 18, 2007 im building a bike with no lights and i would like to get rid of the handlebar switch. im only going to be running a kill switch from the wires off the key switch. just need to know how i could hook everything up to run the bike without the light/kill switch. thanks for any help! Quote
Stellar Performance Posted November 18, 2007 Report Posted November 18, 2007 As long as you keep your key switch.....you can unplug the handle bar mounted light/kill switch. It actually sends a ground to the cdi to kill the motor when in the off position. I used to install a tether kill switch on all of my bikes as an extra kill switch, but your key will do just fine. :biggrin: Quote
flattrakker Posted November 18, 2007 Report Posted November 18, 2007 sorry to bump in but i want to do the same but i want the lights always on.. how do i do that? Quote
Stellar Performance Posted November 18, 2007 Report Posted November 18, 2007 sorry to bump in but i want to do the same but i want the lights always on.. how do i do that? You will have to decide if you want the low beams, or high, and also if you want the tail light on. Your feed wire(power) is the Yellow/Red wire. You will need to connect it to the wires below to determine what you want on. The Low Beam wire is Green The High Beam wire is Yellow THe Tail light wire is Blue Example.....if you want the high beams and tail light on....connect both of them to the Yellow/red wire. You can find all of these wires at the plug where your light switch connects in the front under your gas tank cover. Make sure to make a nice clean and somewhat water tight connection. Quote
Olds Eddie Posted November 19, 2007 Report Posted November 19, 2007 You will have to decide if you want the low beams, or high, and also if you want the tail light on. Your feed wire(power) is the Yellow/Red wire. You will need to connect it to the wires below to determine what you want on. The Low Beam wire is Green The High Beam wire is Yellow THe Tail light wire is Blue Example.....if you want the high beams and tail light on....connect both of them to the Yellow/red wire. You can find all of these wires at the plug where your light switch connects in the front under your gas tank cover. Make sure to make a nice clean and somewhat water tight connection. Quote
Olds Eddie Posted November 19, 2007 Report Posted November 19, 2007 If you do away with the key switch, be sure to ground the switch wire or it won't start. Quote
BellicoseBanshee Posted November 19, 2007 Report Posted November 19, 2007 THIS link may help and add to what was posted above... I know it has a section to clean up the harness, wire in a tether switch, and eliminate the key switch... Quote
