BK2564 Posted September 15, 2007 Report Share Posted September 15, 2007 Hey guys just picked up a shee. I searched the forum and cant find exactly what to unhook to get rid of the tors?? Im not looking into putting any money into it and buying the eliminator kit. Just what wires i have to unhook for it to still run without it? Thanks Quote Link to comment Share on other sites More sharing options...
theshee Posted September 15, 2007 Report Share Posted September 15, 2007 Hey guys just picked up a shee. I searched the forum and cant find exactly what to unhook to get rid of the tors?? Im not looking into putting any money into it and buying the eliminator kit. Just what wires i have to unhook for it to still run without it? Thanks It would be best to get the kit so you can adjust the idle with the screws. Is the TORS messed up? Ive never taken it off without the kit so I dont know what to unhook. Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted September 15, 2007 Report Share Posted September 15, 2007 You should be able to just unplug the black box attached to the frame above the left cylinder, the two carburetor switches, and the throttle housing switch. Try it and if the banshee will not run, plug it all back in. Quote Link to comment Share on other sites More sharing options...
BK2564 Posted September 15, 2007 Author Report Share Posted September 15, 2007 thanks for the info guys...the problem im having with the bike is just in the low rpms it seems like the motor wants to shut off and quit, may just need some carb work tho. I uplugged one on the carbs while it was running and the bike died. I may have to look into the eliminator kit then. Its a 96 fresh top-end about 20 mins. on it, pretty much stock got it for $1000 Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted September 15, 2007 Report Share Posted September 15, 2007 thanks for the info guys...the problem im having with the bike is just in the low rpms it seems like the motor wants to shut off and quit, may just need some carb work tho. I uplugged one on the carbs while it was running and the bike died. I may have to look into the eliminator kit then. You need to unplug all of the components, not just one switch. The control unit will kill the power if a fault is detected in one of the switches. It is worth the $59.99 for a TORS elimination kit. Toomey, Vito's, Motion Pro, etc. are fine, and appear to be comprised of the same components. Quote Link to comment Share on other sites More sharing options...
shee rips Posted September 15, 2007 Report Share Posted September 15, 2007 mine was acting up and all i did was unplug the black box above the left cylinder :thumbsup: Quote Link to comment Share on other sites More sharing options...
BK2564 Posted September 15, 2007 Author Report Share Posted September 15, 2007 thanks for the replies guys I'll have to try it out tomorrow...Im not used to all this electrical crap on a bike, im used to my 250r's Quote Link to comment Share on other sites More sharing options...
AJC Posted September 15, 2007 Report Share Posted September 15, 2007 dont want to hyjack the thread but.. what are tors?.. Quote Link to comment Share on other sites More sharing options...
nunyabinness Posted September 15, 2007 Report Share Posted September 15, 2007 T.O.R.S. (throttle over ride system) its the big metal boxes on top of the stock carbs. they are supposed to kill the power if your throttle gets stuck wide open. Quote Link to comment Share on other sites More sharing options...
John Posted September 15, 2007 Report Share Posted September 15, 2007 T.O.R.S. (throttle over ride system) its the big metal boxes on top of the stock carbs. they are supposed to kill the power if your throttle gets stuck wide open. Not trying to thread jack, but when I look at TORS eliminator kits I see they say they work with stock carbs only. Is there a different version to work with upgraded carbs. I was considering this winter to go up to some 28mmPWKs but I am going to eliminate the TORS first on my stock carbs. Quote Link to comment Share on other sites More sharing options...
Handyman Posted September 16, 2007 Report Share Posted September 16, 2007 Not trying to thread jack, but when I look at TORS eliminator kits I see they say they work with stock carbs only. Is there a different version to work with upgraded carbs. I was considering this winter to go up to some 28mmPWKs but I am going to eliminate the TORS first on my stock carbs. Only the stock carbs will have the eliminator kit available. ANy aftermarket carbs will not have the TORS eliminator kit and oyou will only need a new throttle cable. The eliminator kit will be the cheaper way to go. Otherwise just unplug all the TORS connectors and go from there....Should run just fine. Quote Link to comment Share on other sites More sharing options...
John Posted September 16, 2007 Report Share Posted September 16, 2007 Only the stock carbs will have the eliminator kit available. ANy aftermarket carbs will not have the TORS eliminator kit and oyou will only need a new throttle cable. The eliminator kit will be the cheaper way to go. Otherwise just unplug all the TORS connectors and go from there....Should run just fine. So upgraded carbs don't need the TORS removed since it doesn't have it on them? I figured I would need a new throttle cable. Just wanted to clear it up before I bought anymore parts for my bike. Quote Link to comment Share on other sites More sharing options...
Handyman Posted September 16, 2007 Report Share Posted September 16, 2007 So upgraded carbs don't need the TORS removed since it doesn't have it on them? I figured I would need a new throttle cable. Just wanted to clear it up before I bought anymore parts for my bike. You are correct...When buying new carbs you will have to decide what size you want and buy two...You will have to let the guys at the shop know that you are putting them on a banshee so they can get the correct throttle cable for you...Or PM or call Jeff and FAST and see what he says. Jeff's name on here is FASTOYS Quote Link to comment Share on other sites More sharing options...
BK2564 Posted September 16, 2007 Author Report Share Posted September 16, 2007 well i got all the tors stuff unhooked on the shee, it did fix my problem. Quote Link to comment Share on other sites More sharing options...
