jbooker82 Posted May 30, 2007 Report Posted May 30, 2007 One of my friends got a 1994 Banshee. It has fmf pipes on it. I was wondering if any body could give me some info on wich ones these are. They have FMF stamped in them then it looks like there is a little name stamped in them down under the FMF Logo. Apprears to be Bill sombody. I was just wondering if they were the standard pipe fmf made or if the were gnarly's maybe even the FMF Rev pipe that I herd they made back in the day. Here is the only pic I have right now. I will see if I can get him to send me some more or maybe he will post some. Thanks for you time josh Quote
Snopczynski Posted May 30, 2007 Report Posted May 30, 2007 One of my friends got a 1994 Banshee. It has fmf pipes on it. I was wondering if any body could give me some info on wich ones these are. They have FMF stamped in them then it looks like there is a little name stamped in them down under the FMF Logo. Apprears to be Bill sombody. I was just wondering if they were the standard pipe fmf made or if the were gnarly's maybe even the FMF Rev pipe that I herd they made back in the day. Here is the only pic I have right now. I will see if I can get him to send me some more or maybe he will post some. Thanks for you time josh It looks like the torque pipes, but I need a side view of the headpipe and the chamber to be sure. If it is them, it should rip pretty good. Quote
FireHead Posted May 30, 2007 Report Posted May 30, 2007 One of my friends got a 1994 Banshee. It has fmf pipes on it. I was wondering if any body could give me some info on wich ones these are. They have FMF stamped in them then it looks like there is a little name stamped in them down under the FMF Logo. Apprears to be Bill sombody. I was just wondering if they were the standard pipe fmf made or if the were gnarly's maybe even the FMF Rev pipe that I herd they made back in the day. Here is the only pic I have right now. I will see if I can get him to send me some more or maybe he will post some. Thanks for you time josh You need to get a better side shot of the bike. They might be FMF Hi-Rev's. That reminds me that I need to buy a set of them to hang on my wall. :geek: Quote
jbooker82 Posted May 30, 2007 Author Report Posted May 30, 2007 I email him and told him about it. That is the only pic I have of his machine. He will probably put a couple more pics up. The silencers dont even have end caps or turn downs. Just a flush welded aluminum end with the hole in the end. You have to pull the baffle out from the back to re pack the silencers. Quote
papa_smurf49319 Posted July 3, 2009 Report Posted July 3, 2009 sorry to dig up an old post but i have these same pipes down and my garage and have no idea what they are. Quote
Snopczynski Posted July 3, 2009 Report Posted July 3, 2009 Need a better side shot of the header tubes. Quote
papa_smurf49319 Posted July 3, 2009 Report Posted July 3, 2009 dont have access to the quad tonight but the tube follows the frame, its straight and doesnt expand to much. Quote
papa_smurf49319 Posted July 5, 2009 Report Posted July 5, 2009 Also i noticd that these pipes dont use any orings like the stock pipes, is there a special donut or gasket i need or do i just put em on. Will they leak? Should i use high temp rtv? Quote
sinisterboo Posted July 14, 2009 Report Posted July 14, 2009 That name under where it says fmf is "don earl' founder of fmf. now you've been schooled..... Quote
Snopczynski Posted July 15, 2009 Report Posted July 15, 2009 Thats pipe is the old mid-early top pipe they made. The Nickel Gold series that come out in the 1993 range was its predecessor. If the header tubes appeared to have straight angles instead of a gradual curve like the one you have pictured, then those would have been the torque pipes. Quote
rubeat Posted August 9, 2009 Report Posted August 9, 2009 Thats pipe is the old mid-early top pipe they made. The Nickel Gold series that come out in the 1993 range was its predecessor. If the header tubes appeared to have straight angles instead of a gradual curve like the one you have pictured, then those would have been the torque pipes. I have a set of pipes like these are they any good or should i try to find something else? Thanks Quote
MRMOONEY Posted August 9, 2009 Report Posted August 9, 2009 I have a set of pipes like these are they any good or should i try to find something else? Thanks they dont have much bottom end but once you hit the power band they run pretty good. I used to have a set and loved them but i rode in the sand and i loved when the power band kicked in. They probably wont be to good for trail riding or anything like that. just my .02cents Quote
