The shees rear fenders are starting to sag a little. Anthing to help them stay perked up?
Cascadeinnovations.net has some fender supports..They go under your fenders and hold them up..They bolt to the grab bar area....
A dremel tool or jigsaw.... J/K no I dont know what would stand them back up... Seems like when things sag, they stay sagged.
You can buy fender support brackets for them here http://modquad.com/store/search_results.as...mp;txtCatName=2
I had a set that I was using till I decided to hack my rears and they did a pretty decent job. I would let you have them, but I don't have any clue where the hell they are now.
actually, i just saw that cascade has the same ones for about a buck and a half less. http://cascadeinnovations.net/
Edited by korndawg
just go to any hardware storeand bye some 2 in wide galvanize steel flat bar or alluminum , it dosn't have to be real thick , cut them about 8 in long, put them in a vice and bend them till they fit , drill a couple holes . very easy and cheap.
i have heard something about a heat gun that takes the white marks out of a fender that has been bent. i wonder if you could just heat them up alittle on the underside and then pull then up alittle or use a pice of wood to hold them up intill they cool down ? accualy i have a set of old rears that i had rolled. i think i may try that with my old fenders. i will let you know how it goes.
heat them from the bottom until the get flexible ,bend them to where you want them and throw a bucket of cold water on them and your done. :thumbsup: :thumbsup:
does this accualy work or where you just saying to try it? if it does icould have saved myself quit abit of money lol
My rear fenders on mine looked like they were a little droopy so I took a dremel tool and hacked em off lol.Rebel
Thats what I suggested! LOL :whistling:
  • 2 weeks later...
Wouldn't that leave that heated area hardened, loose it's flexibility after hitting it with heat? Let me know if that works for you.
  • 2 months later...
i heated the fender on my bike to get rid of the white creases, and it got hard and snapped off without even crashing.
i may have been a bit exessive with the heat though lol propane torch :shrug:
