hillclimb Posted August 24, 2006 Report Posted August 24, 2006 I bought a 421 cheetah off a guy. The right side is not firing. The left is perfect. I changed the plugs, its has a spark, the jets are not clogged, the carbs are in sink with each other. What I'am I missing? Quote
dajogejr Posted August 24, 2006 Report Posted August 24, 2006 Swap spark plug wires, do a compression test. Quote
bansheerage Posted August 24, 2006 Report Posted August 24, 2006 maybee an air leak on the right side?? Quote
BrockMoto Posted August 24, 2006 Report Posted August 24, 2006 Compression,Compression,Compression!! Quote
J-Madd Posted August 24, 2006 Report Posted August 24, 2006 Swap spark plug wires, do a compression test. What he said Quote
hillclimb Posted August 30, 2006 Author Report Posted August 30, 2006 Checked compression 150 on both sides, changed plugs, swaped wires, double checked manual. Plugs are firing, reeds looks good, carb jets are not clogged. What next? Quote
dirtyernie52 Posted August 31, 2006 Report Posted August 31, 2006 tors unplugged? crossover tube between carbs missing? Quote
hillclimb Posted August 31, 2006 Author Report Posted August 31, 2006 No tors and no cross over tube to deal with. Its a powervalve can one of valves be a problem. Or possible the CDI is missing the timing? Quote
Dinner Posted August 31, 2006 Report Posted August 31, 2006 Fuel turned on all the way? While running on the left cylinder, pull out the choke while giving it gas to see if it will start sucking it into the right side. Quote
dirtyernie52 Posted August 31, 2006 Report Posted August 31, 2006 do a leakdown test. you have an air leak. Quote
sheefreak Posted August 31, 2006 Report Posted August 31, 2006 do a leakdown test. you have an air leak. I agree! Quote
hillclimb Posted September 1, 2006 Author Report Posted September 1, 2006 Did a leak down test here I'am missing a little corner off of the reed so I ordered a new one. Hopefully this fixes it! Quote
addicted Posted September 1, 2006 Report Posted September 1, 2006 Did a leak down test here I'am missing a little corner off of the reed so I ordered a new one. Hopefully this fixes it! What kind of stator do you have? I have the same motor and was having the same problem. Trinity told me it was because of the Ricky Stator. It was brand new and ohmed out correctly so I didn't beleive them but after not being able to find the problem, I bought an Yamaha stator and the problem dissapeered. Trinity says that motor will not run right with a Ricky. I don't know why but whatever. Quote
hillclimb Posted September 1, 2006 Author Report Posted September 1, 2006 I'am sure what kind of stator it is but it looks stock. I really don't think the busted reed is the only problem. The spark plug is as clean as when I put it in. No burn marks. but I'll find out. Quote
dirtyernie52 Posted September 1, 2006 Report Posted September 1, 2006 Did a leak down test here I'am missing a little corner off of the reed so I ordered a new one. Hopefully this fixes it! a leak down test will not tell if you have a broken reed. it will still fire on a broken reed. if you have spark on both plugs at the same time it is not your stator. your problem is fuel or air. Quote
