  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
You are looking at about $2300- 2500. Which are Cubs with clean up port, new crank, piston's, seals, pancake bearing, etc. But then it also depends on the other goodies that you decide to add to your order. Like for me I added the lock-up clutch, +4 extended swinger, which also needs a longer chain..........and on , and on, and on
Hope this helps
Here's my best guess:
Cylinders: $850.00
Crank: Probably around $600 or so, just guessing.
Porting: ?????????
Cool Head w/ Big Bore Domes: $350.00
Pistons: $300.00?
Bigger Carbs: $350.00
Seals, Gaskets, etc.: ???????
It's gonna run ya close to $2000.00 I'd think
Dude, just what you have up there adds up to $2450.
Do yourself a favor and contact a reputable builder, Jeff at FAST, Jim at Passion, there's also A&S, and many others. they can give you what they would charge to do this, plus you need to factor in 225 for labor to put it together unless you are going to do it yourself...........
That price I said the first time also includes 35 mm Airstyker's w/ pods............. :beer:
"Here's my best guess:
Cylinders: $850.00
Porting: ?????????
Pistons: $300.00?
It's gonna run ya close to $2000.00 I'd think"
+heavy clutch -100
+intakes for bigger carbs/reed spacers to clear clutch arm/Filters outerwears - 135+
+longer swinger like stated above - 300+
+timing plate highly suggested- 35
+crank weld highly suggested - ?
+heavy clutch -100
I'd say 3grand or more. Especially if you are starting from scratch.
here is an ACCURATE price list. ive had 2 built, i know what they cost.
cylinders - 900
porting(optional) - 250
head with domes(optional) - 260
piston kit - 130
wristpin bearings - 20
seal kit - 25
stud extenders - 25
4mm crank(optional) - 450
10mm crank(optional) - 975
lockup and cover(optional) - 325
heavy duty clutch(optional) - 100
35mm carbs(optional) - 325
there are so many variations you can do. you need decide what stroke you wanna go with first, and go from there.
rebel3190, my bro just had exactly what you want done for 1500...that did not include the crank.
Yeah...I've got a stock stroke 68mm cub, and I even forgot to list a few things. LOL :yelrotflmao: . Hell I've probably got 3 grand in mine, I guess. I don't even keep up with the money I put in these things anymore. :jesterlaugh:
I got a brand new 4mm cub motor that I was gonna put in a drag bike, but I just don't have the money or time right now to finish it.
I'd sell the motor complete with stock side covers for 2500
This comes with a new NOSS Head
New Cylinders
New Pistons
New 4mm Long Rod Crank with TZ Bearing
For 3000, you get intakes, VF3 Reeds, and your choice of PWK Carbs
For 250 more, you get an override
For 275 more, you get a polished lockup cover/lockup
Gonna put it in the forsale section soon, unless I change my mind :P
I'd say I got about 2.5-3.5k in just my engine. never gone through and totaled it all up. I get parts off ebay a lot though and do all my own work so its a little cheaper than a builder. Besides, I don't like other peoples hands inside my engine. That when it FUBARS itself I can only blame one person.
What kinda carbs should i run i was thinkin like 35mm air strykers
Heres what all i think ill need,tell me if i miss somethin
Cub Cylinders 68mm bore,aggressive dune port,4mil Weisco Crank,longer rods,Weisco forged pistons,all the seal,gaskets ect.Noss cool head with 17 or 18cc dome which ever are betrer,VForce3 reeds,cases ported,crank trued and welded,35mm air strykers with k&n pods and outerwears +4 swingarm.
Edited by Rebel3190
