jeepman128 Posted March 29, 2006 Report Share Posted March 29, 2006 (edited) OK... I was out at Glamis last weekend where the bike ran perfect for the first day and a half, on the second day, it developed a miss at wide open throttle when the bike would come on the power band. It acted like it was running rich but when I pulled the plugs Edited March 29, 2006 by jeepman128 Quote Link to comment Share on other sites More sharing options...
cdwood37 Posted March 29, 2006 Report Share Posted March 29, 2006 Check your ignition man I fought with that problem and found out it was my ignition do you have stock or aftermarket? Quote Link to comment Share on other sites More sharing options...
Fastrat Posted March 29, 2006 Report Share Posted March 29, 2006 A miss at WOT could be a bit too lean of a main jet. Pulling old plugs wouldn't tell you much of anything. Take into account the change in conditions on the second day. I always look to carbueration befofe ignition, just more typical to have problems there. Quote Link to comment Share on other sites More sharing options...
87banshee350 Posted March 29, 2006 Report Share Posted March 29, 2006 i messed with mine for weeks, and it was the exact same thing as yours sounds and i replaced the coil and plug wires $38 and has ran perfect since then Quote Link to comment Share on other sites More sharing options...
creamsickle Posted March 29, 2006 Report Share Posted March 29, 2006 sounds like a lean main jet. plug chops arent always accurate. what size are you running in the carb. check the float bowl level. I doubt you are sucking the carb low but still always good to check. what is the timing? Quote Link to comment Share on other sites More sharing options...
jeepman128 Posted March 29, 2006 Author Report Share Posted March 29, 2006 The timing is at +4 and the jetting is a stock pilot with a 180 main jet. I have tried a 175, 185 , 190 and 200 (keinn single carb) as well with no positive result. It ran the same with the exception of the 200 where it really started to miss on the top end. I am tending to think it is in the ignition like a few have you mentioned because it literally changed in the blink of a riding break on the second day. There was no change in the weather for the 15 minute break and it continues to run that way since I have brought it back here to Phoenix. Is there any specific way to check the ignition, or should i just replace the O.E box, coil and wires to see if that is the problem? Quote Link to comment Share on other sites More sharing options...
87banshee350 Posted March 29, 2006 Report Share Posted March 29, 2006 thats the same as mine i put bigger mains in and it got worse, i would just get a coil and wires Quote Link to comment Share on other sites More sharing options...
H300F Posted March 30, 2006 Report Share Posted March 30, 2006 I have had every ign part go bad at one time. from my experience the cdi only acts up when it gets splashed with water, the coil and plug wires cause a break up at wide open, stator causes a break up at wide open. Quote Link to comment Share on other sites More sharing options...
Big Blue Posted March 30, 2006 Report Share Posted March 30, 2006 check coil, plug caps, and your gap on the pickup. Quote Link to comment Share on other sites More sharing options...
jeepman128 Posted March 30, 2006 Author Report Share Posted March 30, 2006 Thank you! Thank you! Thank you to all that responded... turns out it was exactly what a few of you had mentioned. The coil and wires were bad,I bought new ones this morning per your advice and installed them and now she runs like a champ. This site is truly helpful and i am very appreciative of the hours of diagnosing you saved me! Thanks again! Quote Link to comment Share on other sites More sharing options...
