BlackBanshee50 Posted February 20, 2006 Report Posted February 20, 2006 Well...Im making the plunge. Im getting it in may or june. I know the banshees have been the same for the last however many years but I prefer to buy new. It just seems to save me alot of headaches. Id like to know a little bit more about them. I always hear they break down alot. How true is this and what is the usual cause? What should I do to keep my banshee running good? What is the best thing to upgrade first? What does your normal maintenance consist of? Sorry about all the questions. Just curious. Quote
korndawg Posted February 20, 2006 Report Posted February 20, 2006 (edited) The first three things you will want to buy for your banshee, in this order: 1. Clymer manual-this will answer pretty much all of your maintainance questions 2. A good set of pipes and some jets-This is a must have. The stock banshee pipes are worthless. Also, you're going to need to rejet pretty much anytime you change anything that effects how much fuel and air you are moving thru the motor, such as changing pipes. 3. A box of kleenex-So all those guys riding four pokes will have something to dry their tears with after you're done kicking their asses. Banshees do require a good deal of maintanance. The best thing you can do, is to figure out how to do it yourself. If you've got a friend that knows how to work on them, see if they can help you out, or feel free to ask questions on here. They really aren't very hard to work on for the most part. If you haul it to the dealership every time you need it worked on, it will end up costing you a small fortune. Edited February 20, 2006 by korndawg Quote
Kayleigh Posted February 20, 2006 Report Posted February 20, 2006 haha that last advice was the best! i have no advice for u...i know nothing of the shee....but i just had to say how jelous i am that ur getting a brand new one! ur gonna have so much fun! rock on! Quote
thegroup Posted February 20, 2006 Report Posted February 20, 2006 ud be better off buying used b/c ull end up losing out in the end. if u buy used, uve already saved on pipes and what ever else. id buy new only to help my credit Quote
korndawg Posted February 20, 2006 Report Posted February 20, 2006 ud be better off buying used b/c ull end up losing out in the end. if u buy used, uve already saved on pipes and what ever else. The only really big benefit of buying new, other than helping your credit, is the fact that you don't have to worry about how it's been used and abused in the past. If you buy a used bike, even if you have to do a complete rebuild, it should still end up being at least a couple thousand cheaper than buying a new one, and the used one should run better, because it should already have pipes and other stuff that you will eventually end up buying for a new one. You just have to watch out if you buy a used one, and make sure you're not getting screwed. Quote
thegroup Posted February 20, 2006 Report Posted February 20, 2006 The only really big benefit of buying new, other than helping your credit, is the fact that you don't have to worry about how it's been used and abused in the past. If you buy a used bike, even if you have to do a complete rebuild, it should still end up being at least a couple thousand cheaper than buying a new one, and the used one should run better, because it should already have pipes and other stuff that you will eventually end up buying for a new one. You just have to watch out if you buy a used one, and make sure you're not getting screwed. 476236[/snapback] now that onyl depends on how much u paid for it in the 1st place. i only paid 2250 for mine, and it already hada few things on it that i was going to do anyway which saved me a goo chunk(single carb, pipes, coolhead, wisecos) the new major deal will be a 400 and port and ill still be under new price Quote
BansheeBrian Posted February 20, 2006 Report Posted February 20, 2006 Happy first post to you.You can get yourself a real rippin, chrome/billet out banshee for the cost of a new one.Get a good used one and stick close to the HQ. Quote
banshee tuner Posted February 20, 2006 Report Posted February 20, 2006 Buy a new one from alba with pipes and a few other mods for the same price as stock, did not know about them until I had allready bought. albaaction.com Quote
lonestar Posted February 20, 2006 Report Posted February 20, 2006 The first thing you change is the stock air filter set up . Don't even run it. Go with pro-design set up. IT comes with air box adapter. This should be your first mod. good luck Quote
Banshee~ Posted February 20, 2006 Report Posted February 20, 2006 (edited) Get an airbox adaptor and k&n filter Click Here Run good oil (for mixing with gas and tranny fluid), clean filter often, and how you ride it all effect the life of your motor. I got the nossmachine adaptor before I did anything to my banshee and tell him your a bansheehq member and you get a discount. Edited February 20, 2006 by Banshee~ Quote
[email protected] Posted February 20, 2006 Report Posted February 20, 2006 my best advice is gunna be to read , i read everything there is to know about banshees and i still know nothing . lol just kiddin , read around on here man use the search option adn you will learn quite alota stuff Quote
Bansh88 Posted February 20, 2006 Report Posted February 20, 2006 If it's your first quad. Just learn to ride it. Stock is fine at first. Once you're comfortable with it, look into pipes. Toomeys are great. Banshee's have the rep of breaking down because there are SO many of them. Lots of them have been bored out, built up, modded to hell and those are the bikes that end up with problems. Quote
BlackBanshee50 Posted February 20, 2006 Author Report Posted February 20, 2006 Thanks for all the advice. Im pumped. What oils do you reccomend? Does anybody have SST pipes on their shee? I have an SST on my bike and it made a very big difference but I never heard anyone mention them on their shee. Quote
[email protected] Posted February 20, 2006 Report Posted February 20, 2006 (edited) stick with the brands people use , dont try to be differnt running stuff not common toomeys , fmf's , cpi ( id go with them ) , or Grand river racing inframes ( if they even make inframes ) , i run there drag pipes and i sware by them they are the best dog diggty pipes on the market ! keep her stock until ure ready to waste money... afterall isnt a banshee around 6000 out the door new ? you can get a used one and have the hole bike rebuilt for near a 1000 and have all the coolest billet n pipes allready ..... buy used , with the intent to rebuild the motor soon . my 1/2 0.02 Edited February 20, 2006 by [email protected] Quote
