bombedbanshee06 Posted February 11, 2006 Report Posted February 11, 2006 (edited) VALVE, THROTTLE won t go down after change the neddle ii put the old 1 back in as it dose the same thing what could this be fixed it was the idle screw threaded Edited February 16, 2006 by bombedbanshee06 Quote
wesw Posted February 11, 2006 Report Posted February 11, 2006 wow that is awful english and hard to understand something is binding. is the needle going down the needle jet hole for the main. or your cable is bound or something. Quote
bombedbanshee06 Posted February 11, 2006 Author Report Posted February 11, 2006 wow that is awful english and hard to understandsomething is binding. is the needle going down the needle jet hole for the main. or your cable is bound or something. 471710[/snapback] its ok if the cable not attached Quote
2003LimitedBanshee Posted February 11, 2006 Report Posted February 11, 2006 The first thing that pops into my mind is that the slides are reversed. This would not be affected by either needle, otherwise I would wonder if the needle was not correct for the app. Check the slides for starters. Otherwise check the cable and then watch the needle through the back of the carb to make sure it is lining up with the main jet bore. Quote
wesw Posted February 11, 2006 Report Posted February 11, 2006 its ok if the cable not attached 471731[/snapback] replace the cable. it you still have the tors on top of the carbs now is a perfect time to get rid of them and put new caps on and a cable. Quote
yellabanshee Posted February 11, 2006 Report Posted February 11, 2006 dude... the slided are in the wrong carbs.... been there before..........make sure the to look in the air box to see the curved side of the slide is facing the intake ............and in sink too pm if ya need more help and have a beer.......it makes it easier to fix heehee Quote
bombedbanshee06 Posted February 11, 2006 Author Report Posted February 11, 2006 dude... the slided are in the wrong carbs.... been there before..........make sure the to look in the air box to see the curved side of the slide is facing the intake ............and in sink too pm if ya need more help and have a beer.......it makes it easier to fix heehee 471814[/snapback] i did them seperate Quote
banshee tuner Posted February 11, 2006 Report Posted February 11, 2006 The slides might be in the right carbs but in backwards, they have a groove in one side that lines up with a pin in the carb. The cutout has to face the filter side. Quote
FIRST BANSHEE Posted February 12, 2006 Report Posted February 12, 2006 its ok if the cable not attached 471731[/snapback] ifthey go down with the cable disconnected, I would check at the splitter, make sure thats not bound up. Quote
Banchetta Posted February 12, 2006 Report Posted February 12, 2006 Problem is obviously the cable if the slides go down w/o the cable...just replace it....why chance using a junk cable and having the throttle stick wide open....this is a no brainer!!! Quote
bombedbanshee06 Posted February 13, 2006 Author Report Posted February 13, 2006 Problem is obviously the cable if the slides go down w/o the cable...just replace it....why chance using a junk cable and having the throttle stick wide open....this is a no brainer!!! 472389[/snapback] The bike is brand new been ridden once Quote
FIRST BANSHEE Posted February 13, 2006 Report Posted February 13, 2006 The bike is brand new been ridden once 472700[/snapback] If the slides move up and down freely with the cable disconnected, but is bound when hooked up the problem is the cable orthumb throttle. Quote
