My AC Sixpack Rack needs some straightening. It looks like the previous owner popped the bike up, and it got caught on the sixpack rack bending it upward at about a 25 degree angle. What do you guys recommend for straightening back into shape?
id put it in a vice and heat it up with a torch and try bending it back... if all else fails go to ebay and pick up a cheap used one and clean it up adn polish it real nice
467485[/snapback]
I've never worked with aluminum. A friend of mine said that it would discolor it by applying heat? is this true, or is he smokin something good?
I have the same rack--i put a 5 foot pipe throught it and bent it by putting my weight on the pipe. Check for cracks at the rear of the subframe also---mine had 2 cracks by the voltage regulator welds area
467617[/snapback]
yes, if you heat it real hot
but it polishes out
alum is soft and bents back with little heat and a long bar
i landed a jump on my grab bar once, bent that thing till it was straight up, after my ass stopped hurting and i got the road rash to stop bleeding, i had my buddy run it over with his truck a few times,,,,, looked like shit, but got me through the day... lol then i bought a new one off ebay.... :headbang:
