iceman Posted January 30, 2006 Report Posted January 30, 2006 when i try to put the nut on the tie rod ends they just rotate. what the hell do i do? Quote
Shee-Male Posted January 30, 2006 Report Posted January 30, 2006 That means they're toast!, time to replace them. Quote
Tim C Posted January 30, 2006 Report Posted January 30, 2006 Sounds like the threads got banged up - did you beat on the threads when removing it? Quote
PUSH THE THROTTLE Posted January 30, 2006 Report Posted January 30, 2006 Sounds like you are talking about the balljoint. It's a tapered connection. Might tap the backside with a dead blow hammer or rubber mallet. Once the taper seats you can tighten the nut properly. Quote
iceman Posted January 30, 2006 Author Report Posted January 30, 2006 sorry. i shouldve explained. when i put the balljoint into the steering knuckle it doesnt grab it. then when i try to thread the castle nut on the balljoint just spins. im thinking im not hitting it hard enough to seat it. i just dont want to break it or anything. i was hitting it pretty hard though. ill try again and see if that works. Quote
sanddragon2004 Posted January 30, 2006 Report Posted January 30, 2006 i try to hold the steering one direction to put leverage against the joint and loosen it up. Quote
[email protected] Posted January 30, 2006 Report Posted January 30, 2006 i got however many balljoints you need 5 each + 5 shipping pm me if intrested Quote
PUSH THE THROTTLE Posted January 30, 2006 Report Posted January 30, 2006 i try to hold the steering one direction to put leverage against the joint and loosen it up. 466569[/snapback] That's a good idea too, anything that will create a little friction so that it will start pulling on the taper. I suppose you could always loctite it and let it sit for awhile and then thread the nut on. Quote
iceman Posted January 30, 2006 Author Report Posted January 30, 2006 alrighty. i got the outer one seated. i realized the tie rod is in the wrong way. i also forgot to check the length on each end. does the direction of the rod really matter? and does the length matter? they looked even but i didnt measure them. they fit and the steering works. i just cant get the steering stem joint seated. ive been hammering at it for a while and its very hard to get to. nothing pisses me off more than when i work on things that just arent working. i might try the loctite thing. thanks guys. Quote
sanddragon2004 Posted January 31, 2006 Report Posted January 31, 2006 you could also wedge a pickle fork in their to put pressure on it but only do that if your going to throw it away, which i assume you are. Then you could hit it with an impact to just get it off. that shouldnt damage the spindle. just trash the ball joint. which is bad anyways. Quote
iceman Posted January 31, 2006 Author Report Posted January 31, 2006 im not trying to get it off lol. im trying to get them on. should i not use them if they rotate like this? also when i move the boot to the side no grease comes out. isnt grease supposed to come out? im gonna be pissed cause i spent 30 bucks on them. not much but i couldve used it better if they are bad. Quote
iceman Posted January 31, 2006 Author Report Posted January 31, 2006 (edited) alright. im thinking im just gonna get some tusk ends. i shouldve done that in the first place. ill just be out 30 bucks. i dont want to go through the trouble of returning them or anything. does that sound like a better idea than trying to make these ones work? Edited January 31, 2006 by iceman Quote
PUSH THE THROTTLE Posted January 31, 2006 Report Posted January 31, 2006 alright. im thinking im just gonna get some tusk ends. i shouldve done that in the first place. ill just be out 30 bucks. i dont want to go through the trouble of returning them or anything. does that sound like a better idea than trying to make these ones work? 466968[/snapback] I use the Tusk ends and haven't had any problems with them. I'm still not understanding why it won't tighten though. Are your ball joints worn or is it your steering stem? It should tighten up no matter if your ends are shot or not. Were they loose before when you took it apart? Quote
[email protected] Posted January 31, 2006 Report Posted January 31, 2006 i pmed you the other day about the ball joints here is what i have for sale , the ball joints are ez to remove and will go right over to banshee no problem . my auction http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMESE%3AIT Quote
