sanddragon2004
Everything posted by sanddragon2004
  1. this is the big dodge manual with all the schematics and codes very comprehensive. cost me 95$ selling for 65bucks shipped. call 408 209 5586 or email me at [email protected]
  2. and TT racers. flat trackers.
  3. the yfz450 frame is dramatically different then a banshee. completely different camber / caster, and leverage ratios on the shocks. I cant imagine that front end handles better then a +2 banshee setup with some yfz shocks. seems like it would have horrible bump steer, and looks like the camber is way off. with no way to adjust it.
  4. +1 on the recommendation for a +4 swinger, thats what i ran on my 60hp 350 and it seemed just perfect! id prob stay away from an 8" unless ur spinning more then 85hp and are only going to drag, and plan to change the shock and or spring.
  5. I have a new set of fireball arms i bought for my yfz decided to go extended with stock shocks for the time being they are new in the box and have candy red powder, almost a perfect match to the red yfz frames. asking 440 shipped for the set. call 408 209 5586
  6. Fireball racing makes an arm for the banshee specifically engineered to work with the yfz shock. I think they are like 399.99 for a set. and you can reuse your spindles and front end simply just changing the shocks.
  7. yes they are, but no sorry i dont have shocks for them, they are standard long travel. 18.5-19.5" shocks.
  8. I have a set of new yfz 450 long travel a arms, they are fireball racing arms brand new with candy red paint. they require a 18.5-19" shock. come with everything to bolt in. new these are 599.99. im asking 425 shipped.
  9. non heim jointed, and they are for stock shocks,
  10. was going to run this on my bike and decided to go with a steel axle instead. brand new in the box never opened. 34" fireball billet axle for banshee. 460 shipped.
  11. I have a set of brand new bare banshee +2+1 A ARMS . new in box never used never mounted. 340$ shipped. call 408 209 5586. will take paypal. <<<<NOTE pic is powdercoated, actual set are Bare metal>>>>>> thanks for looking.
  12. yes they will! and they work awesome! honestly the best setup i have ever run! I am not here to advertise , but fireball racings a plus 2 arm setup for yfz shocks it works awesome! best setup for the dollar. the stock yfzs will also work but you have to adjust the springs preload a bit. with it being a heavy bike they are a great shock far better then the stock setup by far.
  13. sorry man just looking for cash money.. 300 shipped.
  14. I have a brand new set of silver vein fireball racing a arms that im selling. new in box never used we decided to go a different route on the setup and are selling these. 380$ shipped to lower 48 states. email [email protected] if interested. ps i have better pics just they are too large to post on here.
  15. 270 shipped. black red, silver and i think blue available. Im helping roger sell the parts. the long bolts are stud girdles that screw into the cylinder base studs. 18-20-22cc domes available at present. this was the first run. not available for the cheetah motor yet.
  16. interesetd in trading for quad parts?
  17. FIREBALL STARTED MAKING THESE AGAIN. I have received a few to sell as a favor to roger. complete ready to bolt on use the existing studs 1 peice design very trick items.
  18. I am selling the following items. all prices are negociable. you can buy all or seperate. all prices are shipped. if you purchase more then one item i will combine shipping to lower shipping costs if applicable. Red anodized aluminum hiem joines for fireball racing a arms 1 ride in dirt for 5 mins 105$ will work with any fireball racing arms, or should work with quick sand, american star or most heim joined a arm front ends. 1 complete set - 1 heim and one spacer kit for banshee/yfz450 front end. kit includes 3 heim joints. 4 spindle studs. 2 top bar spacers for a arms all the spacers but 1. asking 45$ the hiems are used but the spindles are brand new as well as the spacers. 1 set oem banshee carbs 25$ 1 billet banshee kicker 55$ 1 bansehe chain saver case guard 15$ 1 banshee on off switch 9$ 1 set foam air filters for 34mm and up carbs 25$ 1 radiator 35$ 1 radiator shroud blue 15$ 1 radiator shroud with coolant guage yellow 17$ 2 billet brake block offs 10$ for both. 1 air box eliminator bracket 8$ 1 oem honda 250r swimg arm from 86-87 250r 56$ 1 oem yfz 450 06 axle. take off part never used 86$ 1 38mm keihin pj carb 56$ shipped. 1 85 act 250r coil 22$ 1 04 yfz450 rear shock brand new never used 100$ 1 87 banshee rear shock, missing adjuster, 50$ 1 05 trx450r oem axle 70$ email me at [email protected] or reply here. I can post pics but they are high resolution so i dont know if i can fit all of them. thanks for looking.
  19. btw i have seen complete running 250rs for 1500-2500 in my neck of the woods. 4 years ago those bikes would fetch 3-7k. crazy where the markets gone.
  20. Hey bro, I have owned about 20 diff 250rs over the years and this is very common. first off to fix this right you are going to be replacing that case, which will require splitting the cases on the motor. all new gaskets and seals. get a good casesaver and you shouldnt really have that problem again. its common though when u dont run a good chain and sprockets if the chains are loose or streched the play can throw them and 250rs dont have good chain guides like the banshee or other bikes. hope that helps. bill at r-central.net can help you. U owe it to yourself to become a member on that site. tons of good info and tons of awesome helpful members.
  21. dang rzbansheeman you have done some serious swapping around! question why go from 3/4 ton back to half ton ? just curios and curios what you thought of the gear ratious with the TH 350 with out OD over the 700r4s?
  22. LOL
