KJO89 Posted December 28, 2005 Report Posted December 28, 2005 My freind was riding my banshee and it stalled. So we started it back up and it stalled when it started to accelerate. Then it wouldnt start. We let it sit for a few mintues and it started and did the same. Now it wont start at all. Anyone know what this is? Help please! Quote
KJO89 Posted December 30, 2005 Author Report Posted December 30, 2005 does anyone have any idea??? i need help Quote
Dinner Posted December 30, 2005 Report Posted December 30, 2005 (edited) Maybe when you stalled it those 3 times you fouled the plugs...check them and wipe them dry to make sure they arnt all wet, or else they wont spark, or just put new ones in, and let us know if that helped at all Edited December 30, 2005 by Dinner Quote
mike23 Posted December 30, 2005 Report Posted December 30, 2005 may check your wiring harness, make sure it didn't get up against your pipe. Could be a loose ground Quote
sheefreak Posted December 30, 2005 Report Posted December 30, 2005 Unplug the TORS box under the gas tank on the shifter side of the quad. Sounds like that could be your problem. You can just leave it unplugged, just won't automatically shut down if your throttle sticks. Quote
1000dollabill Posted December 30, 2005 Report Posted December 30, 2005 had the same problem. check your connections on the coil. ground might be loose. Quote
KJO89 Posted December 30, 2005 Author Report Posted December 30, 2005 (edited) i changed the plugs so thats not the problem, and i just unplugged the tors and still no change. when i kick it over the lights dont light up or anything either. Edited December 30, 2005 by KJO89 Quote
banshee tuner Posted December 30, 2005 Report Posted December 30, 2005 Check the kill switch, I was riding one day and mine got wet and when I went to crank it it would not do anything. Quote
KJO89 Posted December 31, 2005 Author Report Posted December 31, 2005 (edited) i looked and the key switch wire wasnt plugged into anything. There are two wires, that arnt in anything. They dont fit in. So i dont know Edited December 31, 2005 by KJO89 Quote
97shee Posted December 31, 2005 Report Posted December 31, 2005 i had somthing similiar to that happen and i had a broke reed Quote
MILO Posted December 31, 2005 Report Posted December 31, 2005 need a little more info here. was it running fine before it stalled out? almost sounds like you just need a good carb cleaning, or maybe air filter? if the plugs are new, make sure your getting spark to eliminate electrical issues before tearing into every electrical component. start with the simple things first. getting spark, getting fuel, carbs/filter clean, crossover tube in place, choke functioning properly, fouling plugs, bad reeds, loose/dirty connections etc. then if it still won't fire up, look a little deeper. Quote
FASTOYS Posted December 31, 2005 Report Posted December 31, 2005 What is the compression . Maybe he siezed it up ! Quote
KJO89 Posted December 31, 2005 Author Report Posted December 31, 2005 well its runing fine now. just the only thing is i dont need the key anymore to start it....lol, i wont keep it like this just for now until i can do it right. Quote
96dragbanshee Posted January 9, 2006 Report Posted January 9, 2006 ok if it still doesnt work check the resistance on your ignition coil. mine did that and my ignition coil was shot. The resistance should be between 1000-4000 ohms. if that is right see if there is a short between a black wire in the harness and orange one. If there is then your bike will not start until you repair that. the ignition coil would be where i would start. Quote
