97shee
About 97shee
  • Birthday 09/19/1975
Contact Methods
    texarkana/arkansas
    97 shee hot rod crank bored 65 over cool heads pro flow kit boost bootle lone star a arms works shocks fmf fattys +4 timming shaved flywheel 18cc domes 108 octane race fuel pro taper bars billett flywheel and clutch cover
97shee's Achievements
  1. i had somthing similiar to that happen and i had a broke reed
  2. castrol gtx made my clutch slip
  3. 97shee
    paddle tires
    i have sand stars on heavy rims on my banshee now. if i change to 21inch 7 paddle haulers how much of a diffrence can i expect
  4. i just rebuilt my top end and now i have water getting on one of my cylinders. i took the head back ogg and replaced all of the o rings and noticed a flat spot on the side of one og the domes. i put it all back togother but it is still leaking water on my cylinder. is the cause oh this the flat spot (looks like a dent where it may have been droped)
  5. i have a 97 shee. i need a new clutch and was told a street bike clutch is what i need. what kind og street bike clutch will work and where do i get it
  6. is my pilot the one next to my main connected to the float. if so how do i tell waht size it is. i pulled it out but thier are not any numbers on it
  7. elevation 330
  8. i just rebuilt my top end and need to know what jets to run. here are my mods. boost bootle pro flow kit with filter stock carbs with stock needles + 4 timming advance shaved flywheel fresh bore .70 hot rod crank coolheads 18cc domes stock reeds fmf fatty's with powercore silencers will be running 112 octane if anyone can help i would appericate it
  9. i have a 97 banshee that i am putting rockets on and i need to know what jets to run and where to set the needles. here are my mods .60 bore hot rod crank pro flow kit stock needles boost bootle degree key cool heads shaved flywheel i am going to use u 4 racefuel 1100ft elevation
  10. i am thinking of putting rockets on my 97 shee, could someone send me some pics of thier rockets installed [email protected]
