Put a big zip tie on them, but feed the tie backwards so the it will come back off. Make sure the the ring is seated right on the little pin in the piston that hold it from turning
If the jugs a freshly honed, you may need to put a little chamfer on the bottom, otherwise they should pup in 1 at a time with your fingures, make sure it is the right ring (size wise) rare, but sometimes get packaged wrong.
would it be a bad idea to put some premix oil on the rings and piston to help slide it in?
443611[/snapback]
You are supposed to prelube your top end w/the same premix oil you will be running in the first place! I belive the instructions from your pistons even tell you that! Once you lube everything up, you should have no problem getting those pistons to slide into the cylinders w/just your hands.
Like PUSH THE THROTTLE said, the piston should go into the cylinder pretty easy if you have the gap in rings lined up with the marks on the piston, otherwise they will not go into the cylinder and cause dammage if you try to force them.
