Ive beeen looking at those dual outlet pingel's. They look pretty dope.
So I say; if your sure you have to replace your petcock, mite as well do a little upgrade while your at it.
Though they are sorta spendy
While your on the subject, does anyone know if there is any interference between a pingel and Rockets? Stock is pretty tight, just made me wonder.
I myself would probably go with the pingle, fuel supply can be an issue (bowles running very low on fuel) with a fairly modded she and certain carbs when going WOT for a long ass time.
I have had some half way running out of fuel in the carbs situations on a long hill climbs when the tank is getting low. Not sure if the pingel would have solved the problem but would probably help.
385264[/snapback]
i agree, if you don't mind the price then get the pingle.
385415[/snapback]
when i go to duel 35mm's from my single 35mm i plan on getting the pingle. while doing a little searching a while back for prices and such i noticed that on the ones that i saw there was only one short input (basically a screen) so it would help when your tank is low while going up or down a hill (to a degree). if it matters to you or not you will not have the reserve option like you would with the stock petcock but you will definitely have better flow.
Just tried the link
click on fuel valves and inline filters on the left and then click on dual feed on off only. They are like 73.95 on here.
https://shop.pingelonline.com/iwwidb.pvx?;multi_item_submit
try this link if it doesnt work . try    www. pingelonline.com and look around untill you find the dual feed for the banshee.
Probably the cheapest you will find it anywhere. Unless Scott (sredish) happens to have another one.  thank you much again Scott.  For the pingel and the beadlocks
Later
385828[/snapback]
Also scope out ebay- I saw one go for round $50
I see that Pingel makes a few different types of valves.  Which ones are you guys running?
385862[/snapback]
There website actually lists the one for the banshee. It is just dual feed. Only draw back is that there is no reserve.
