ive been thru alot of probs puttin some 28 pwks in now ive got most of them taken care of.found out in jettin that i was loosin spark thru my coil so i replaced it with a aftermarket one.during full throttle im noticing that it feels like im runnin out of fuel, it did it before i replaced the coil and still does it. anyone have any ideal what this could be?it doesnt do it all the time and if i let of the throttle and hit it again it feels like it ok but a few sec later it will do it again if im runnin wide open.
It might well be running out of fuel.
-Blocked gas tank cap vent or hose
-Blocked petcock filter screen
... if i let of the throttle and hit it again it feels like it ok but a few sec later it will do it again if im runnin wide open.
385183[/snapback]
That makes me think your mains need to be bigger.
J.J. ... Partially blocked, maybe. But 'blocked' will lead to a 'no run' situation.
rare.
ive thought that question about my mains being too small but i called sudco who makes the carbs and put the pilot main and needle that they told me too. at first i bought the carbs from a friend that had them jetted real radical to big on everything including the needle and it still did the same thing.i do have a inline fuel filter but it looks like its clean and fuel comes out pretty easy.but my plugs looked nice light tannish and the motor runs strong just until it chokes out like its runnin out of fuel.i checked for leaks around the carbs and the intakes but everything is good?? any suggestions?????
Before I got rid of my f**kin UNI I had little peices of foam stuck in my carb, one peice even made it into the needle and seat and the bike ran hard until the fuel bowl was empty then it would die, wait a couple of mins and it would do it all over again, pull you bowl and float and have a lookie-boo.
385814[/snapback]
F-in POS foam filters
385814[/snapback]
a lookie-boo :confused:sheemale, you're really beginning to make me wonder about you! :huh:
