Banshee 79 Posted February 25, 2005 Report Posted February 25, 2005 (edited) I have a K&N Air Filter With Outerwear, Airbox Lid On, Snorkel Removed. I have FMF Fattys With Powercore Silencers. I was Wondering If Anybody Is Running This Setup And What Mains There Using And Pilots And Clip Position Thanks!!!!!!!!!!!!!!! I Am 927 Feet Above Sea Level. I have four 1 inch by 1 inch holes cut in the airlid. Edited March 1, 2005 by Banshee 79 Quote
J.J. Posted February 25, 2005 Report Posted February 25, 2005 Mine at sealevel: Fattys + K&N no lid 300~320mains depending on temp and humidity 27.5 pilots airscrew 1.5~ 2 turns out depending... needle in the middle Quote
Banshee 79 Posted February 25, 2005 Author Report Posted February 25, 2005 Thanks For The Reply That Will Give Me A starting Point!!!!!!!!!!! Quote
J.J. Posted February 25, 2005 Report Posted February 25, 2005 (edited) No probs, it's a starting point at best, you have to do the fine tuning yourself. Edit: How impolite of me, welcome to the HQ, hope you're hear to stay Edited February 25, 2005 by J.J. Quote
Ducman Posted February 25, 2005 Report Posted February 25, 2005 Same as J.J.'s jetting except run 280 mains since you have the airbox lid on. Quote
Banchetta Posted February 26, 2005 Report Posted February 26, 2005 270 w/ the lid on, needle 4th clip from the blunt end, stock pilots.. Quote
fastbanshee4u Posted February 27, 2005 Report Posted February 27, 2005 I have a K&N Air Filter With Outerwear, Airbox Lid On, Snorkel Removed. I have FMF Fattys With Powercore Silencers. I was Wondering If Anybody Is Running This Setup And What Mains There Using And Pilots And Clip Position Thanks!!!!!!!!!!!!!!! 329481[/snapback] when I bougt fattys long time ago fmf said 260 mains and 30 pilots Iit ran good at all rpms. do some plug readings when you get it broke in Quote
Yamaholic in va. Posted February 28, 2005 Report Posted February 28, 2005 [280 mains,27.5 pilots, ] Quote
Banshee 79 Posted March 2, 2005 Author Report Posted March 2, 2005 Should I Buy A jet Kit Or Just Individual Jets? Quote
sonnydlt Posted March 4, 2005 Report Posted March 4, 2005 I have the same setup but im running with lid on but no snorkel. i have 260 mains and stock pilot and clip. it runs very well no fouling or hesitation through out the entire rpm's. useing hc1 @ 40:1 im at 1200 above sea level hope this helps Quote
Banshee 79 Posted March 4, 2005 Author Report Posted March 4, 2005 I have the same setup but im running with lid on but no snorkel. i have 260 mains and stock pilot and clip. it runs very well no fouling or hesitation through out the entire rpm's. useing hc1 @ 40:1 im at 1200 above sea level hope this helps 333195[/snapback] Thanks for the reply,that will give me somewhere to start,sounds like the same setup!!!! Quote
sredish Posted March 4, 2005 Report Posted March 4, 2005 Should I Buy A jet Kit Or Just Individual Jets? 332133[/snapback] Just buy individual jets. The jet kits hardly ever have what you really need and they're too expensive. Just buy main jets from 270 to 310 and a 27.5 pilot and you'll be set, until you get it ported. I'm guessing 270 to 280 on the main as well with the lid on. Quote
richybanshee Posted March 4, 2005 Report Posted March 4, 2005 Take airbox lid off and put 280 -300 mains, needle in the 4rth clip position, stock pilot jet like 1 turn out from seated. With lid on and no snorkle: 260 mains Quote
