(Banshees with STOCK carburetors only please reply)
Please copy and paste this along with your answers in your reply, thanks.
1) What type of aftermarket exhaust do you have?
2) What type of airfilter do you have?
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )
5) What size pilot jets are you using?
6) What size main jets are you using?
7) What temperature is your Banshee jetted for?
Edited by anufsed
Toomey T5's
Dual K&N Pods w/Outerwears
D
4535
30
310
75-90
I don't feel like copying and pasting. Also, look on www.bluetraxx.com They have some nonsense like this......
I am running FMF fatty's, Stock airbox, no lid, with a UNI foam filter, 800' above sea level, 27.5 pilots, 310 or 320 mains. I am jetted for about 70-80F. Any colder, and I throw the lid on. Or, re-jet....
Pro Circuit
K&N
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
Aftermarket air box, no lid but has outerwear w/velcro to cover opening
667ft.
30
320's now, may need to go to 310's
70-80 degrees
Edited by banshdog
Same as Boonman, except I have K&N
Strange that your research doesn't involve needle type and clip position...
no..i know anufsed..he is not a dumbass by any means. he is just doing a little research seeing what everyone is running and what seems to be working. Not real sure why he didn't add needle position etc.
Toomey T5's
K&N
D
1000-1500
30 i believe
370
65-90..depends on where i ride.
rockets
see above
d
see above
30
tried anywhere from 360-410..nothing seems to work worth a shit..but its getting better)port work doesn't match the pipes..not to mention all of the other problems
see above
1. T5s
2. Toomey 2:1 air filter.
3. No airbox.
4. 500' elevation(Glamis)
5. 30 pilots.
6. 370 mains.
7. 50-70F
Old-School FMF top-end pipes
K&N
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all \
Stock airbox, with lid, snorkel removed
Not sure
Stock
260
60 degrees to 85 degrees
CPI
K&N PODS
D
2000
27.5
470
7) What temperature is your Banshee jetted for? 65-70
  • 2 weeks later...
wow, another question would be porting if any? timing?
I have
T-5s
clamp on K&Ns
15 tooth front/stock rear41?
27.5 pilots, stock needle position, 280 main jets
and run 50:1 Redline/87 octane fuel
(more than enough octane,stock compression/timing)
no portwork done (yet)
Pro Circuit
Toomey 2:1/UNI
d) no airbox at all
aprox. 1200
:rolleyes: Ride in all different temps...never really screw with the jetting to be honest with ya. :huh:
Toomey T-5
Single K/N
3) Are you a)running a stock airbox with lid cool.gif stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
airbox with 12 vents no lid (my single K/N airbox mod)
580'
stock no sure
270
Texas Summer's 90+
pro circuit
uni
stock with snorkle removed
800feet
27.5
280
32-95F
Edited by oih8u2
TOOMEY T-5
Twin K&N
No airbox
sea level
27.5
350 needle in middle
65-75 degrees
