right above the carbs on my bike there is a thing that the throttle cable runs through before it goes to the carb and my new twist throttle manual shows me no such part or what to do with it so could someone tell me what it does and what to do????
Thanks
its tors (throttle override system), big black piece of shit! get a tors removal kit, you'll be happier everyminute, i swear they cause 80% of banshee problems
what is a TORS removal kit man cause my new throttle come with new tops of the carbs that thread on an adaptor for the cable to go in!! its a motion pro twist throttle what do i do with all the electronic shit that goes with TORS
that should work , but if you want to add the idle kit u would have to by the idle screws , their 5.00 bucks a peice, yopu will have to unplug the black box and tors wires , do a search there is lots of info on this site.
shit can all of it...... those new tops are for your twist to go straight into the carbs and pull the slides up and down, if you dont understand it, take it to a shop, under a 100 bucks someone will install it for you, they will aslo tap your carbs for an idle adjustment.....
thanks guys but one last question what exactly is TORS put on there for i am kinda new at all this my bike is my dads old bike i am only 16 and i wanna race so i need to get some performance stuff any ideas on what else could be put on i am gettin FMF SST pipes next month
The TORS is a peice of crap that works kind of like a throtle positioning sensor. If the slides in the carbs are stuck in the open position the TORS will cut the ignition. It also serves as a rev limiter. It was put on the quad to cut the amount of Lawsuits Yammaha would get. The problem is that it is a peice of $hi+ and malfunctions half the time causing more problems than good. DITCH IT!!!!!
The tors will help you out racing the same as if you straped a brick to your grab bar. :P But really ditch those things as soon as you can,the money you'll spend on the kit is well worth all the problems you'd have down the road with the tos.
TORS stands for Throttle over ride sensor i beleive if that further answers your question. Every wire that is related to it, disconnect.
Its been 3 years and I have no problem to report with my TORS system.Its just like anything else,if you don't maintain it,sooner or later its not going to work.
I take the covers off once a year to clean out the housings.Periodically cleaning and regreasing the electrical connections will also prevent electrical problems.
Mine will stay on as long as they keep working properly or I upgrade to better carbs.
