nyb Posted December 3, 2022 Report Posted December 3, 2022 just switched from inframes to oof pipes and the stinger is to close to the rear tire. is the stinger a tuned length or ok to trim a little length. stock frame and stock length swingarm. Quote
locogato11283 Posted December 3, 2022 Report Posted December 3, 2022 How much would you need to trim to accommodate tire growth? You will lose some RPM by shortening the stingers. They are that length for a reason. Why stock length? Buy a +2 arm and solve all your problems. Quote
nyb Posted December 4, 2022 Author Report Posted December 4, 2022 probably would have to trim 1-1/2" to be safe. i guess thats the way i will go longer swinger. stock length for better turning , i ride it in the woods sometimes. thanks Quote
SKEETER Posted December 4, 2022 Report Posted December 4, 2022 Chop a few inches off. Wont need the rpms for da woodz 💁♂️ Quote
kawa110 Posted December 5, 2022 Report Posted December 5, 2022 Oof hard for right cornersSent from my iPhone using Tapatalk Quote
kawa110 Posted December 5, 2022 Report Posted December 5, 2022 Tight***Sent from my iPhone using Tapatalk Quote
specialblend07 Posted December 5, 2022 Report Posted December 5, 2022 OOF for wood riding... this sounds like my type of situation!!!!! Quote
nyb Posted December 5, 2022 Author Report Posted December 5, 2022 im not a pussy, worst case you crash. Quote
specialblend07 Posted December 6, 2022 Report Posted December 6, 2022 Nothing can go wrong there. Quote
Tedder Posted December 27, 2022 Report Posted December 27, 2022 I've been told by two builders who make pipes not to cut the singers any shorter than 10" Quote
OMW2FYB Posted March 3, 2023 Report Posted March 3, 2023 On 12/26/2022 at 9:20 PM, Tedder said: I've been told by two builders who make pipes not to cut the singers any shorter than 10" stinger length really only effects the sound, cutting a inch off of the stinger wont effect the rpm enough, if at all (to the guy above) people have their own theory's on how a pipe works, its physics. Quote
